Original => Hot Tub Forum => Topic started by: raymel1 on June 25, 2015, 02:22:42 am
Title: Hot Springs Model Number help
Post by: raymel1 on June 25, 2015, 02:22:42 am
 CK 241118 is the serial number, ive tried looking it up but came up empty...any help is appreciated. Thanks!  :)
Title: Re: Hot Springs Model Number help
Post by: raymel1 on June 25, 2015, 09:36:41 pm
Evidently the serial # on the Hard Top Cover is not the same as the one inside the Hot Spring highlife Serial # K-141119 which is inside the door where the pump and things are located.
Post by: Dr. Spaâ„¢ Ret. on June 25, 2015, 11:56:08 pm
Highlife
Built in the first quarter of 1994
Gallons   415
Dry Weight (lbs)   665
Wet Weight (lbs)   4,130
Footprint Dimensions   8' 4" x 7' 2"
Electrical Specifications   230 Volt. 50 Amp Single Phase G.F.C.I Protected Circuit
Original Selling Price (Approx.)   $6,995
Post by: raymel1 on June 29, 2015, 02:12:00 pm
thank you! I need to find a Manual for that.
