Original => Hot Tub Forum => Topic started by: pbsteelers26 on December 19, 2014, 02:57:50 pm
Title: Chemical Kit
Post by: pbsteelers26 on December 19, 2014, 02:57:50 pm
Purchased my first hot tub any users have suggestions/ recommendations on best/ most efficient chemical kit on the market?
Title: Re: Chemical Kit
Post by: Quickbeam on December 19, 2014, 03:36:50 pm
I am assuming you are looking for a chemical test kit??? If so, you might want to check out the Taylor chemical test kits. They have a number of different test kits depending on what you are using for a sanitizer.
Post by: Pacificpoolandspa on January 05, 2015, 09:42:14 pm
In terms of efficiency, I would just use test strips.  They are fairly effective (although not as accurate as the Taylor kit).  It takes a few seconds to test whereas the taylor kit will take you 5-10 minutes depending on how fast you drip!
Jeff
www.pacificpool.ca
