Brand Specific Forums => Hot Spring Spas => Topic started by: leanne369 on November 03, 2013, 01:12:31 pm
Title: Jetsetter Hot Springs 2000 model wont' heat above 94
Post by: leanne369 on November 03, 2013, 01:12:31 pm
I know the heater is working since it does get to 94.  I am wondering if the temp sensor is messed up or maybe the water level is a little low.
Any thoughts, tips would be most appreciated.  I am a new owner of this older hot tub and am just learning about maintenance.
Title: Re: Jetsetter Hot Springs 2000 model wont' heat above 94
Post by: Hot Spring Official on November 15, 2013, 04:55:42 pm
Hey leanne369,
You may look to clean/replace your filters!  That could do the trick!  Or it is likely a sensor/component issue that a dealer could help you with!
Thanks,
Post by: hottubdan on November 16, 2013, 11:46:48 am
Wouldn't surprise me if it is temp sensor. (Thermister)
Post by: Flyonthewall on November 16, 2013, 01:53:23 pm
sound advice.  no flashing green or red lights?  if it was a 2001-current model the symptoms would point right at the heater board (something not part of the 2000 jetsetter).  are you 100% on the year?  serial # should have a B in it for the 2000 models.
Post by: Chas on November 21, 2013, 06:53:11 pm
Your initial assumption is in error: your tub can easily climb to the mid-nineties without the heater being on at all. The little circulating pump can do it all by itself, assuming the tub has a good cover tightly fitted.
You have a reset button on that heater (unless it has been updated) and I would start with that. However, it WILL NOT reset if the heater is above 90 degrees. Simply shut off the power and wait several hours. Leave the spa cover closed: no sense it cooling the entire tub, just the heater.
HTH
