Original => Hot Tub Forum => Topic started by: sfchein on September 28, 2013, 06:46:42 pm
Title: Sodium Carbonate or Sodium Hydrogen Carbonate for Hot Spring Spa
Post by: sfchein on September 28, 2013, 06:46:42 pm
I have the new Gleam model Hot Spring Spa. PH was low so I got some ph Up- Soda Ash from my local Home Depot. Is this a safe alternative until I can order some from my Hot Spring dealer?
Thanx for your help.
Title: Re: Sodium Carbonate or Sodium Hydrogen Carbonate for Hot Spring Spa
Post by: Chas on September 29, 2013, 12:20:13 am
You don't mention what reading you got for TA (Total Alkalinity) so I can really answer. But I will say this: Baking soda from your kitchen or laundry room will raise both TA and pH, but after things settle a bit, the TA will be a bit higher than pH.
HTH
Post by: sfchein on September 29, 2013, 01:45:24 am
Thank you for your reply.
I believe it was at about 180 and PH was about 7.2..., maybe a shade less on the color strips.
Post by: chem geek on September 29, 2013, 12:38:23 pm
You can see a variety of grocery/hardware store equivalents of pool & spa chemicals in this post (http://www.troublefreepool.com/blind-faith-and-this-forum-t23196-20.html#p190888).
