Original => Hot Tub Forum => Topic started by: hottub63 on March 17, 2013, 02:38:30 pm
Title: Need picture of inside of hot springs sub panel
Post by: hottub63 on March 17, 2013, 02:38:30 pm
Could someone please send me a picture of the inside of their hot springs sub panel box (with the dual breakers.).
I want to confirm mine is wired correctly. Thanks.
Title: Re: Need picture of inside of hot springs sub panel
Post by: kurt6137 on March 19, 2013, 05:53:20 pm
Never go by pictures for electrical wiring, get the diagram from hot springs web site, depending on your series tub, you can download the owners manual in pdf format and it will show you exactly how to wire it. On the high life series tubs, they have a 4 conductor from the 50 amp breaker main panel, it then goes into the sub panel, how you wire the neutral wire is important. So, like I said, never go with photos, go with a diagram from the manufacturer of the tub.
Post by: hottub63 on March 19, 2013, 06:12:08 pm
Thanks..we got it all hooked up..
I just wanted to see a picture of the box that comes from Hot Springs since they should all be hooked up the same...
But it's all good now. Thanks for the reply.
