Original => Hot Tub Forum => Topic started by: TdiDave on February 09, 2013, 10:57:25 am
I have a Jacuzzi 480 and was wondering what the consensus is on the run time of the circulation pump? I think the default is 12 hours but does anyone have a opinion of more or less run time?
I was told if outside to run 24hr.
Go 24 hours with it!
Twelve hours, twice a day.
Just had my hot tub installed and they set up the circ pump for 24 hours and 10 minutes ;D
Any idea on the flow rates for the circulation pump?
I prefer 8 hours, three times a day.
From what I read, it pumps 35 gal per min. So it will pump or thus filter a 415 gal tub in about 12 min. So the water will be filtered 5 times a hr., and 120 times a day.
Seems like a lot but a typical 190 GPM jet pump filtering for 4 hours will do the same thing.
So far I am finding the 12 hours works fine. I suppose it might depend on how much you use your tub if its enough. In the 4 months I've owned mine, i haven't found a reason to change it yet.
