Original => Hot Tub Forum => Topic started by: xenus7850 on October 25, 2012, 08:08:22 pm
I have a 2000 Blue Ridge hot tub, made by Juccuzi and keep geeting a PS1 error code. I have done the following;
1. Cleaned the filters
2. Cleaned the screens underneath of the filters
3. Installed a new circulation pump
4. Installed a new pressure switch on the heater
5. Took an air hose and blew error through both filters to make sure the line were clear (bubbles seen at the intake areas inside of the hot-tub).
6. Check the volts that feed the circulation pump (225-231 volts).
7. Drained and filled the hot tub.
When I turn the circuit breaker on to give power to the hot tub, I will hear the control box make a clicking sound, a few seconds later the circulation pumps starts circulating the water for 2-5 seconds, I hear another click come from the control panel and the circulation pump shuts down. It will reset and go through this process 3-5 times, then stops for good until I reset the power again.
I am out of ideas for trouble shooting, my next step is to pull the circuit board and have it rebuilt. I am hesitant to do this as for some reason I don't think that is the issue, any other ideas?
Did you ever figure this out?? I’m having the same issue!
