Original => Hot Tub Forum => Topic started by: Howarth on September 22, 2012, 10:18:24 am
Title: Clearray Hot Tub Help Needed ???????????
Post by: Howarth on September 22, 2012, 10:18:24 am
Hi
Has anyone bought a Clearray Jacuzzi ?  We have had ours since April and it has been a nightmare.  We have had the radio replaced and are in the process of dealing with their head office regarding the chlorine required to get a decent reading.
Every day the chlorine, ph levels and alkalinity is permanently low on the reading sticks.  The amount of chlorine we have to put in to get a reading is ridiculous.
I have written to them now to see what can be done as something is definitely not right.  I am scared to go in it as there is far too high levels of chemicals in it for my liking.
Would appreciate it if anyone can help.
Title: Re: Clearray Hot Tub Help Needed ???????????
Post by: Jacuzzi Jim on September 22, 2012, 11:30:16 am
  Have you tried talking with your dealer?   How does your water look,clear,cloudy does it smell like a stinky sock?     How's your PH/Alk?  How often are you adding chlorine, how old is the water and when was the last time you shocked it?   In most cases it's the spa owner and not the spa's fault if you are having chem issues, if your dealer has left you hanging I am sorry, but I would love to know what your nightmare has been other than a bad stereo?
Post by: TwinCitiesHotSpring on September 22, 2012, 12:04:46 pm
it sounds like you need a proper chemical "orientation"...call your dealer and explain that your having troubles with water care and that you would like some assistance
Post by: planetary on September 22, 2012, 12:47:26 pm
Have you read Nitro's guide to using Chlorine (http://www.troublefreepool.com/how-do-i-use-chlorine-in-my-spa-or-pool-t10095.html)?  Not because you should necessarily use his treatment regime, but because if you set out to understand it, you'll end up learning a lot of useful concepts.
BTW, that forum (Trouble Free Pool) seems to be a good place to go to talk about water chemistry stuff.
Post by: Hottubguy on September 22, 2012, 01:46:54 pm
Why not just dump the water and start over?  Have you tried testing anywhere else besides with the sticks?  Maybe they are bad.  I also don't understand how you can be afraid to go in because the chemical levels are too high when in your prior sentence you said everything was too low.  I would call the dealer for guidance
Post by: Howarth on September 23, 2012, 04:58:05 am
Hi
Sorry I should have added more.  The dealer is involved.  There are only 2 of us so not loads of people getting in the hot tub.  We add lots of chlorine/ph/alkaline increaser to get reading to correct levels and the next day everything is low again.  This happens all of the time.  The amount of chemicals we are using is not healthy.  We have adjusted factory settings and tried loads of different avenues.  The engineer is baffled also.  We have emptied and tried again.  We are liasing with Jacuzzi at the minute to see if they are going to replace the Clearray system/bulb (not sure on what it consists of) and wiil empty again and start from scratch.
I was hoping to contact someone who has the same system to discuss their experiences.
Thanks for your interest and replies.
Jacuzzi have been good so far!!!???  We'll now see if they can sort it further as they said I am the minority.  I am thankful I have had the engineer involved from day one as he is baffled.
Any replies much appreciated.
Post by: Howarth on September 23, 2012, 05:05:06 am
ps   the water looks ok and doesn't smell.  We have used a variety of different sticks.  It's the readings that are low, I don't fell like getting in it as we know how much chemicals are in the water to get a reading which you may think is fine but the reading has disappeared the following day and needs more chemicals.  Isn't the idea of Clearray is not to use as much chemicals/chlorine?  The other day all levels were correct even the PH/alkaline and the following day everything was low again.  Nobody had been in the tub either.
Post by: Tman122 on September 23, 2012, 07:05:02 am
When you say Chemicals what exactly are we talking here? Are you trying to raise your PH/Alkalitity? So baking soda?
Post by: Jacuzzi Jim on September 23, 2012, 11:13:47 am
I highly doubt clearray is the culprit and curious which mdl Jacuzzi you have?
  The only chem clearray really changes is the amount of chlorine you should be adding, you still have to keep up with PH/Alk no matter what system you use. If you have been adding mega amounts of chlorine then yes you are going to have problems keeping the PH/ALK up.  I am not a fan of maintaining a constant PPM of chlorine, and I know there are a few here that would dissagree with that.   Sometimes it's best to quit trying to get it perfect and let the spa do what it does.   In my own spa with clearray and a family of four with normal use in the spa, using a Proclear cartride (NAT2) I add 1 scoop approx 1 tblspn of chlorine after use sometimes 2 tblspns if more than 2 people. I shock once a week and watch my PH/ALK.   I do hit it hard once a month say 1/4 cup of chlorine if that to kind of nuke it.   Thats it,  and my water stays crystal clear, and I change it every 4 months and sometimes go even longer.     I did this also before clearay ever came out with std ozone, with same results, it worked perfect.    I am not saying this works for everyone but many many of my customers are happy with it.
  Hopefully the "engineer" at Jacuzzi will figure your nightmare out for you, personally I would trust a dealer more than a so called engineer at Jacuzzi which is most likely a service tech that doesn't even own a spa.   Sometimes keeping it simple works best, good luck to you, and let me know if I can help!
Post by: hottubdan on September 23, 2012, 12:08:22 pm
So, Jim, based on your post, what is the benefit of the Clear Ray? Sounds like you are adding as much chlorine as most people do.
Post by: Jacuzzi Jim on September 23, 2012, 12:23:46 pm
  Pretty much, I like Clear Ray and I know it works, but yes You still have to add chlorine as with ozone. I am impartial to it, just another sales tool.   I can cut chlorine out and go the shock after use route then chlorine weekly I just find it easier to throw a bit of chlorine in when I get out.   Call me old fashioned..
 I think Jacuzzi/Sundance should work on a salt system but they never will.     I think it s a sales tool as well but why not be able to offer it and compete against you guys with it.    And FWIW I don't like the aftermarket units like Gecko offers.
Post by: TwinCitiesHotSpring on September 23, 2012, 01:47:49 pm
the point is to use less chemical, but it will depend on your usage...if your an above average or heavy user you'll be adding enough sanitizer so you probably won't see any advantage with the clearray.  Like Jim said these items are used to generate sales, nobody on the market has a "magic pill" system, you still need sanitizer, you still need to adjust pH/Alk. and you still need to shock occasionally
Post by: Howarth on September 24, 2012, 04:00:54 am
Hi
The water looks ok - clear - never smelly - apart from the chlorine!
They are going to empty it next week and start again (for the second time).  The engineer has his own hot tub but not clear ray.  He seems very knowledgeable.
The model is J335.
You could put 50 ml of chlorine in the tub and a few hours later would not get a reading (even if nobody had been in the tub)?
Yes I agree about the ph/alkalinity reducing because of it.  We are using Jacuzzi Alkalinity increaser and Ph increaser.
Post by: ssilver853 on September 24, 2012, 07:09:47 am
Guys...
Although, I have not received my new jacuzzi, I am very familiar with situation.  I have an inground pool and I use chlorine (I have resisted moving to salt).  Two out of the last 4 years , upon opening I've had trouble holding chlorine and have spent hundreds of dollars to fix the problem.  I'm not sure where you live but there are many things that can contribute to this issue.  Weather, believe it or not lawn fertilizer, severe algae, town or well water etc...
Post by: goose973 on September 24, 2012, 08:51:49 am
I have a Sundance with clearray, and it doesn't have the problems you describe. I'm on we'll water. I admit that our well water is excellent. It meets every drinking water standard without any chemical treatment. As long as I get and keep my TA around 120 or so, it tends to be quite easy to tend to the tub. Other than the need to add chlorine and shock as well as baking soda, everything else is almost hands off. Very little need to adjust pH (holds around 7.4-7.6) and I only need to add baking soda every two or three weeks to maintain TA and, in a roundabout way, the pH. I use dichlor granules at each fill and after until my cyanuric acid reaches a good level and then switch to bleach. After each use, I put in about 1/4 to 1/2 cup of bleach. I shock about twice a week with MPS (we use the tub almost every day). The clearray does not keep me from having to use chlorine, but it's nowhere near what you say you're using. That's my experience. Hope it helps.
Post by: Jacuzzi Jim on September 24, 2012, 01:03:43 pm
Hi
The model is J335.
  Other than a smell of chlorine it sounds fine, pick up a talyor test kit and get rid of the strips, then see what kind of readings you are getting.    Enjoy the spa and quit worrying about it.  You are making this harder than it needs to be.    Shock the spa really good, then start using it, wait a day or so before adding anything then  add 1 tblspn of chlorine after use shock once a week, watch your ph/alk.     You should be able to sit in the spa and not smell any chlorine if you do it right.  Good luck to you!
Post by: wmccall on September 24, 2012, 03:59:11 pm
To add to what Jim says, I suspect whatever the issue is , its a tie between the water itself and your test strips.  I don't think this is related to any particular brand of tub and UV system.
Title: 2012 J-480 w. Clearray User - Same Issues - not as big a deal
Post by: Jacuzzi_Kirra on September 28, 2012, 02:27:59 am
I have a 2012 J-480.  I've had some of the same problems, but I don't feel that the spa is not working right.  It's just a very large spa that I have filled to the top, estimated 550 gallons or more.
I keep the water temperature between 104 and 106.  Mostly it's just being used by one person, sometimes two if my wife joins me.
Here's how I've been maintaining the water.
Nature2 Mineral Sanitizer
Leisure Time Spa 56 Chlorinating Granules (1 oz) every 3 days.  Most of the time after 24 hours my test strips indicate 0 ppm for chlorine.  Jacuzzi clearray states that you should maintain at 1 ppm for chlorine.  Very rarely do I need to add 2 oz to bring the readings up on my test strip (Leisure Time) to 1 to 3 ppm.
Nature 2 Cense (3 oz) every time i use the spa (daily most of the time) or at-least every 3 days if non-used.
Today, after 3 months of ownership and with the water always indicating the Calcium Hardness ppm were 50 or less (on city water in Northern CA), I used one entire bottle of Leisure Time Calcium Booster to raise the CH to around 250 ppm.  I think i will add another 1/2 bottle (32 fl oz bottle) tomorrow to raise the level more.  Hopefully this will get rid of the very small amount of water line ring that I had before I started using the Bright and Clear and Defender as described below last month.
Every Weekend on my 3rd day maintenance schedule (hopefully that makes sense), I add Chlorinating Granules (1 oz), 2 oz of Leisure Time Bright and Clear, 2 oz of Leisure Time Defender and my water consistently stays crystal clear (for a few hours after adding all of those items, it will remain cloudy as the chemicals work).
Every once in a while I have to add Leisure Time Spa Up and/or Alkalinity Increaser to maintain the recommended ideal range.
So is this more chemicals then I thought I would have to use with the Clearray - Yes.  Does my water stay sanitized, clear, and not smell of chemicals - absolutely.  Bottom line, it's a lot less work than my 15 year old hot tub that I had before, and I don't get the "chlorine or bromine smell and water marks drying on my skin."
I had researched the Clearray system online prior to my purchase.  It seemed more like a good idea, than a scientifically engineered tested water sanitizer, mainly because the volume of water that is exposed to the UV light, is not exposed long enough to properly kill the bacteria, as in regards to what government requirements are for potable water sanitization.  Jacuzzi claims it will naturalize the bacteria vs killing that bacteria, thus that's why you are still required to use a sanitizer such as chlorine in low dosage amounts.  My belief is it allows for a lower dosage than without it, and it's still more efficient that other gimmicks that have been marketed in the past 10 years.
