Original => Hot Tub Forum => Topic started by: mikey55 on May 29, 2012, 11:53:36 am
Hi,
I was given a thermospa 2000d (2003 I think) that had some freezing damage. I was able to find the manifolds , tubing and flex. Thought I was good to go but on fill up had a leak. One of the fittings that snaps into one of the small jets is split. I have not been able to find this online. Was just wondering if anyone knew where to get thermospa parts? This appears to be specific to thermospa. Or could I replace with a complete jet that fits that size hole? do the jets all have to be the same for any reason? I have a picture but did not knoww how to post it. Not tech savvy. As you can see I also posted in wrong place first time. Thanks for any help.
we are going to need a picture...I highly doubt thermospa was using any "exclusive" jets, more than likely a waterway or similar so replacement parts should be able to be located but I need to see the jet itself
I have a picture but i can't seem to add it. Is that allowed on here? Still no response from thermospa.
(http://www.doityourself.com/forum/attachments/pools-spas-hot-tubs/741d1338229184-thermospa-parts-help-snapshot_20120528.jpg)
That is the piece Doc. Not sure how it got there but that is what I am looking for. Thank you.
By the way, welcome to the forum. Thermospa does, I believe use a lot of common industry parts in their spas, many of them are Waterways parts as are many of the parts in my Dynasty. Identifying them can go a long way to finding replacements.
Thanks for the welcome. I have some news. Finally got ahold of a person at thermospa parts(been trying since tuesday) and ordered the needed part. I ordered a couple extras in case. So hopefully he delivers as promised. I should see the parts tues / wed. I thought they were reasonably priced also. Thanks for the suggestions I will post updates as I go. Just hopeing this is my last leak.
i need the part that plugs on the back of that,any phone numbers or names you can give to help me find this
