Original => Hot Tub Forum => Topic started by: cyendrey on October 12, 2011, 09:28:07 pm
Title: Mineral/Silver santitation - what should I be looking for?
Post by: cyendrey on October 12, 2011, 09:28:07 pm
I've a new Sundance Maxxus and selected the Sunpurity mineral system for sanitation since I understood that it, in combination with the ozonator, would reduce the chemicals needed to maintain the water.  I'm somewhat confused though - what should I be seeing on the MPS test strips, and does this mean I need a lower level of MPS indicated or that it takes less periodic dichlor to maintain the same level indications?
Title: Re: Mineral/Silver santitation - what should I be looking for?
Post by: d00nut on October 13, 2011, 08:03:27 pm
Realistically, you will shock it every week or so with the dichlor if you have the nature 2 stick/cartridge.  You can use the dichlor throughout the week in lieu of the MPS if you'd like as well depending on how much you use it.
