Original => Hot Tub Forum => Topic started by: Kaisermust on July 11, 2011, 09:12:18 am
First of all I want to thank all of you who have responded to my many questions regarding my concerns about certain tubs. We have made our decision to go with the Caldera Kauai because it's size fits our requirements nicely. Now I have a question about which cover-lifter is best for that size tub. Dealer says the cover would attach to the short side of the Kauai which is only 65" wide. I'm thinking I would like either the ProLift IV (needs only 7" of clearance) or the ProLift which takes only 14" of clearance. With the cover hinged in two, am I correct in thinking the cover would extend above the top of the tub by only about 4-5 inches (tub is 29" deep)? Would like air flow around tub to be as unobstructed as possible and not blocked by a big cover in the way. Any opinions as to which would be better (ProLift IV or ProLift) for our use would be appreciated. Oh, and if there's another lifter mechanism out there that would be better please suggest that as well. Dealer is selling us the lifter at his cost supposedly ($250) since he threw in the ozone system in the purchase. Thanks.
I have only used and sold the lifts by Leisure Concepts so I have no experience with the Prolift's. On a spa that small I would use a Covermate Eco since the two sides are not connected nothing has to be cut down to fit.
With the ProLift IV the cover will stick up very, very high. I typically only like selling the Uprite lifts (ProLift IV) (Speaking Hot Spring lingo) when the spa is pushed up to a wall or fence. Reason being, is the Uprite (ProLift IV) will act like a sail in the wind. In the regular pro lift lifter, the cover will stick up pretty high, probably about 2' or more if the cover does go on the short side. (I'm not super familiar with the Caldera cover orientation.) The ProLift II would get the cover down lower than any other lifters they offer. Although, that needs 24" of clearance.
Just a side note. If you do use an "off branded" cover lifter. That of being one not from Watkins, it will void your 2 year stitching warranty on your cover. Got the notice a few months back... just an fyi!
Just as an FYI, there's a federal law (originally designed for the automotive industry), stating they CAN'T void the warranty for NOT using THEIR proprietary products. They CAN though, NOT honor the warranty IF they can prove that the non-proprietary product directly caused the damage... It also puts the burden of proof on "them".
I would look at the Covermate EZ that it was we use on are smaller tubs,
Thanks for the heads up! I think I'll restate that then, they will not honor the warranty if you use a different lift. Since Watkins is the only manufacture to make their own covers, I don't believe they designed them to have a bar rest across the seam. All of Watkins cover lifts physically attach to the cover... just saying.
I thought Sunstar made the covers for Watkin's?
They would have to show that the coverlifter caused the damage in order to not honor the warranty (most cover manufacturers warranty state they will not cover damage caused by any coverlifters anyways...but still they have to show that the damage WAS caused by the lifter).
Watkins make their own covers (NOT Sunstar).
the Magnuson-Moss Warranty Act
http://business.ftc.gov/documents/bus01-businesspersons-guide-federal-warranty-law
""Tie-In Sales" Provisions
Generally, tie-in sales provisions are not allowed. Such a provision would require a purchaser of the warranted product to buy an item or service from a particular company to use with the warranted product in order to be eligible to receive a remedy under the warranty. "
