Original => Hot Tub Forum => Topic started by: neacr1 on August 12, 2010, 09:59:32 pm
Title: Sanitation questions
Post by: neacr1 on August 12, 2010, 09:59:32 pm
Hi All,
I read a post on another forum and Hot Tub Aficionado said "I like the ozone, AG+ and MPS method" as opposed to the spa frog. My Caldera Niagara has the frog system and ozone. I'm not sure what AG+ and MPS are but would like more info if anyone can help with that. I am currently using Bromine because it came in the starter kit but would like to use chlorine (I think) once that runs out. If I switch to chlorine do I still need the mineral cartridge?? I'm looking to treat the water as inexpensively as possible but would like simplicity as well. Is that a pipe dream??
Thanks,
Title: Re: Sanitation questions
Post by: Spatech_tuo on August 13, 2010, 10:59:41 am
Hi All,
Thanks,
When you switch to chlorine just tell your dealer you want to also use Nature 2 (aka AG+) which is a mineral cartidge also. It is a definite help to water care but you can do without it so if you want to save $ you can try just chlorine and see how it works first before you add the Nature 2.
Post by: neacr1 on August 14, 2010, 08:18:59 am
Is there a chlorine cartridge for the spa frog or do I add it manually?
Post by: hottubdan on August 14, 2010, 01:46:53 pm
Add manually.
