Original => Hot Tub Forum => Topic started by: dekakaco on June 20, 2010, 02:37:43 pm
I have had a Caldera Tahian spa for about a year. I change the water about every three months and generally have had very few problems with water balance, etc. thanks in large part to the information I get from this website. The problem I have is cleaning the filter between water changes. I turn off the electricity to the spa and remove the filter for cleaning. But the filter cavity always has dirty water with pine needles, insects, etc. that makes its way into the tub. Is that supposed to happen each time you change the filter?
YUP! If they're floating you can use a pool skimmer to clean them out.
I use one of those little nets you use for fish aquairiums. After taking the filter out, swirl the water around with your hand and then just scoop with the net. Works great for me.
