Original => Hot Tub Forum => Topic started by: Guelphgirl on July 19, 2008, 12:26:05 pm
Title: Maintaining and Protecting Spa Cover
Post by: Guelphgirl on July 19, 2008, 12:26:05 pm
Wondering what is the best way to maintain and protect my vinyl spa cover.
Title: Re: Maintaining and Protecting Spa Cover
Post by: Hillbilly Hot Tub on July 19, 2008, 01:27:38 pm
Spa Blanket will protect bottom side from ozone and chemicals. 303 Spray is the best for the top (IMO) Don't use Aromorall or anything that has petrolium products in them because it will actually break down the vinyal.
Post by: Webini on July 19, 2008, 01:40:07 pm
Agreed.  303 Vinyl Protector is the only way to go.
Post by: Swell-Tub on July 19, 2008, 02:01:16 pm
I do what HillBilly said. Spa blanket and 303. It looks brand new, oh wait it is brand new.....
Scott  ;D
Post by: Vinny on July 19, 2008, 05:04:53 pm
You are going to have to clean the spa cover every so often. I use a bleach and dish detergent mixture on the outside and scrub it with a deck brush, then use 303. I just tried a power washer on it and it came out squeaky clean, once it dries I'll put the 303 on it.
For the inside you need to use either the chlorinated water that you shock with and a rag, bleach and water with a rag or a bleach impregnated wipe to clean and kill the mold/bacteria that may be growing. Some people have put 303 on the inside as well.
The inside will get growths on it and may start to smell after a while.
Post by: Elmo on July 22, 2008, 11:47:16 pm
We've only had the tub (sundance optima) for 3 weeks and the inside of the cover already has tiny spots of mold on it.  Is this normal?  Would a spa blanket help?  Any other ideas on how to stop it or at least slow it down?
Any recommendations on what type (brand) of spa blanket to get or where to order it online?  I've seen a few different ones.  Looks like closed cell foam would be the best.
Thanks!
Post by: Swell-Tub on July 23, 2008, 12:30:36 am
Thanks!
Put a 50% mixture of Clorox and water and wipe the inside of the cover off. I bought my spa blanket from Dr. Spa on this forum. He has a website:
http://www.rhtubs.com/store/float.htm#therm
I bought the foam blanket and not the bubble blanket.
Scott  8-)
