Original => Hot Tub Forum => Topic started by: STEELMAN on June 16, 2008, 12:50:32 pm
Title: 06 GRANDEE PROBLEM NEED HELP PLEASE.....
Post by: STEELMAN on June 16, 2008, 12:50:32 pm
have a 06 grandee and everytime i do a water change my water is crystal clear for
about a month. after that my spa water goes bad and i get a green tint and its cloudy.
i rotate the filters once a month but i just dont understand why the water goes bad only after
one month. i verified that the ozone works and i do weekly routine maintenence. can anyone
chas or tex give me some insight on this. do i have to wash the filters once a month. i hate cloudy water.
oh by the way, when i do add chlorine its clears up but for only like 3 days....please advise...
Title: Re: 06 GRANDEE PROBLEM NEED HELP PLEASE.....
Post by: Swell-Tub on June 16, 2008, 12:52:41 pm
Steelman, what part of the country are you in. I'm no spa tech but it sounds like algae to me.
Scott  :-?
Post by: Steve on June 16, 2008, 01:11:42 pm
I'm not Chas or Termie but is certainly sounds like you're not meeting your chlorine demand. Can you give a more detailed post on your weekly maintenance regime? Are you shocking? What is the reading after shocking? What do you keep your chlorine at regularly and what are you using? Filters can only do so much... if your water balance isn't right, you can clean the filters daily and it won't matter...
Alkalinity? Calcium hardness? TDS out of the tap? Useage?
Post by: STEELMAN on June 16, 2008, 01:52:55 pm
i chlorinate 1x aweek..whatever it is for 500 gallons. i test once a week and notice my ph is between 7.6 and 7.8 and total alk somewhere around 115...it all is within normal range...maybe i need to shock and chlorinate more often or shock more often....prior to shocking the chlorine reading is zero
Post by: hottubdan on June 16, 2008, 03:46:15 pm
Do you use the Freshwater Nature2 cartridge?
How often do you use the spa?  Do you add anything with each use?
Post by: STEELMAN on June 16, 2008, 03:55:19 pm
YES ON THE NATURE2 FRESH WATER TUBE...I USE THE SPAS 2X A WEEK..AND I DO
ADD MPS EITHER 10 MIN BEFORE I SOAK OR AFTER.....I MAY JUST START ADDING MORE
CHLORINE EACH TIME...MAYBE THATMAY HELP....IT JUST SUCKS THAT AFTER 1 MONTH
THE WATER  GETS UGLY...SO FAST
Post by: hottubdan on June 16, 2008, 04:05:41 pm
Yes, try adding chlorine with each use.  Try using the weekly MPS dose.  See what that does.
Post by: Spatech_tuo on June 16, 2008, 07:07:06 pm
AHHHHH, this is EXACTLY while I roll my eyes at those ridiculous N2 instructions. They go that MPS/use route so they can sell it as you using minimal chlorine. There is one problem with that; it doesn't work well.
This is what I tell all first time users as well as those who've already tried one the the many "this will use less of those horrible chemicals that kill bunnies and flowers" methods:
add 1 generous teasponns/person after each soak (without fail),
shock once per week with MPS
check PH/Alk once per week
clean filters monthly, rinse as needed
If it ever gets cloudy (whether you've slipped on the routine or not) just hit it extra hard with chlorine but it should occur seldom if you follow through with the per use chlorine.
Post by: hottubdan on June 16, 2008, 07:19:26 pm
We have hundreds if not thousands of customers who successfully use the MPS with each use and and shock weekly with chlorine. :)
Post by: Spatech_tuo on June 16, 2008, 08:05:17 pm
I can see minimal users getting by on it but I personally see it fail for new users (who obviously use it multiple times a week when its new) regularly.
Post by: Vanguard on June 17, 2008, 11:53:25 am
I noticed you said you rotate your filters once a month.  Then you asked if you need to clean your filters once a month.
How often are you actually taking out your filters and cleaning them?  You should be cleaning them once a month.  Maybe a little more if you use the spa a lot or maybe a little less if you don't use it so much.  But you should be cleaning them.
Post by: Jacuzzi Jim on June 17, 2008, 12:41:40 pm
  So what is the reason for 100% no by pass filtration again?     8-)
Post by: Spatech_tuo on June 17, 2008, 12:45:13 pm
A good filtration system and good ozone will help a lot but at the same time, if you're not sanitizing enough you're going to run into this situation.
Post by: Jacuzzi Jim on June 17, 2008, 01:40:03 pm
  I pretty much know that, I was being a bit of a smart a--
Post by: STEELMAN on June 17, 2008, 02:00:20 pm
I ROTATE THE FILTERS AND CLEAN THEM ONCE EVERY 1.5 MONTHS. I PROBABLY  NEED TO STEP THOSE
CLEANINGS UP. I WILL START TO ADD CHLORINE AFTER I SOAK. IS THAT SUFFICIENT. CAN I ADD CHLORINE AFTER I SOAK AND KEEP THE JETS ON FOR 10 MIN OR SO...HEY THANX FOR EVERYONE CHIMING IN.
Post by: Spatech_tuo on June 17, 2008, 02:08:54 pm
You? No way! ;)
Post by: Jacuzzi Jim on June 17, 2008, 02:13:24 pm
 Chlorine after use or every couple of days is what I suggest.
 Personally I think your green tint is coming from something else.  Speaking with my tech he seems to remember it was a case of to low or to high of PH.  Its been awhile since he had to deal with it, but he remembers raising or lowering PH and the green tint went away almost instantly.  You on a well system?   Or it could be something else??
 Asparagus??
Post by: Jacuzzi Jim on June 17, 2008, 02:16:14 pm
You? No way! ;)
 ;D   Its good to laugh.     I mean that in a positive way!!
Post by: STEELMAN on June 17, 2008, 02:34:07 pm
WHEN I DO ADD CHLORINE ON THE WEEKLY MAINTENENCE, THE GREEN GOES AWAY BUT RETURNS WITHIN A WEEK OR SO....MY PH IS ALWAYS IN THE 7'S AND THE TOTAL ALK IS 120 OR LOWER.... THANX FOR THE HELP JIM....AND I DONT CARE WHAT EVERYONE ELSE SAYS ABOUT  YOU..J/K NOT ON A WELL SYSTEM BY THE WAY...JUST REGULAR CITY WATER IN SO CAL.
Post by: Jacuzzi Jim on June 17, 2008, 02:40:53 pm
  Thats a tough one sounds like everything is where it should be.  :-/
 The good news its nothing that should hurt you!!   Does a dose clarifier help at all, and does the cloudiness go away and the green stays?
Post by: Spatech_tuo on June 17, 2008, 04:22:13 pm
Clarifiers can work well but often times are overused IMO. I think this is a case of sanitize properly first and then if any green tint happens I'd move to a clarifier.
Post by: STEELMAN on June 18, 2008, 01:32:27 pm
CHECKED WATER YESTERDAY EVENING AND NO GREEN TINT....BUT THE WATER WAS A LITTLE CLOUDY.
I CHECKED THE PH AND TOTAL ALK AND THE ALK WAS HIGH???MY PH WAS 7.6 AND ALK 202. DOES ANYONE KNOW A WAY I CAN LOWER TOTAL ALK WITHOUT ADJUSTING THE PH TOO MUCH...THANX AGAIN
Post by: STEELMAN on June 18, 2008, 06:23:04 pm
bump
Post by: Jacuzzi Jim on June 18, 2008, 07:19:16 pm
 Just leave the alk alone it will most likely come down on its own.
