Original => Hot Tub Forum => Topic started by: run1stride2nd on March 03, 2008, 08:20:53 pm
Title: Breaker Keeps tripping - caldera niagara 2008
Post by: run1stride2nd on March 03, 2008, 08:20:53 pm
I have a 1 month old caldera niagara that has a problem this evening :(
When I came home from work this evening, the 30amp breaker was tripped on the GFCI box.  I reset the breaker, and within a few minutes the automatic startup cycle started on the spa.  As soon as the Jets started up, the breaker pops again.
Second time, I manually started the spa back up, and pressed Jet1 and the 30amp breaker trips.
Third time, I manually started the spa back up and pressed Jet2 and the 30amp breaker trips.
Is it the breaker that is weak? or am I having an internal spa problem?  I placed a call to my dealer (after hours) and left a message.
............just looking to see if there's something I can do so we can enjoy the tub tonight, but can be patient to wait until tomorrow.
Thanks in advance for any help.
run1stride2nd.
Title: Re: Breaker Keeps tripping - caldera niagara 2008
Post by: Vanguard on March 03, 2008, 10:55:31 pm
Try cleaning your filter.  You may have a dirty filter that is causing an issue with the heater which could cause the breaker to trip.
One easy way to find out if that is the problem is just take out the filter and see if the breaker still trips.  If it does, call your dealer for warranty service.  If the breaker does not trip, then you have found the problem.  Clean the filter and you'll be good to go.
Post by: run1stride2nd on March 04, 2008, 07:30:30 am
Vanguard,
Thanks for the reply.  Unfortunately, Filter is clean, even tried taking it out, but when ever I press Jet1, or Jet2, the breaker still trips.
Water is 102F, ozone is running, circ pump is running, air works...........just can't start either Jet1, or Jet2 without a trip.
Any other idea's?
run1stride2nd
Post by: Vanguard on March 04, 2008, 10:29:12 am
Probably need to call your dealer at this point.  I'm not much of a technician, but the filter thing is one of the first things people will try.  You're covered under a strong warranty, so not much to worry about.
Post by: hottubdan on March 04, 2008, 10:33:11 am
Sounds like the breaker.  One of the advantages of a Watkins spa is the breakers come with the spa and are part of the warranty.
Post by: run1stride2nd on March 04, 2008, 10:38:29 am
That's what is looks like to me as well.
They just called me, but the tech is off today, he'll be out tomorrow.
.........bummer, 2 nights without the tub. :(
Post by: hottubdan on March 04, 2008, 10:42:09 am
You can soak with no jets. :-?  It's better than nothing. :P
Post by: Im not Dr. Spa on March 04, 2008, 01:19:52 pm
The odds of 2 pumps failing and tripping the breaker is slim to none. Chances are there is another piece of equipment activated when any of your pumps are activated, which is bad, thus tripping the breaker. Some spas have a fan installed that activate when the pump does, does yours?
It's likely that or a bad GFCI. You can pick up a GFCI tester at some hardware stores for around 20 bucks.
Post by: run1stride2nd on March 04, 2008, 02:35:17 pm
Since I'm not an electrician (and don't play one here on the forum) and "fear the black box on the wall," I spoke with Caldera tech support and the dealer (run on sentance??).  Seems that they both feel its a weak breaker and will come out tomorrow morning to diagnose and repair/replace.  The service tech needed a day off today.
I"ll keep ya'll posted on what the end result is.
I'll stick to working on what I know and leave the tough stuff to the experts....... ;)
Since I'm so new at this tub thing, I like soaking with all the jets beating me up, and can't just sit there in still waters....... :D
Post by: run1stride2nd on March 05, 2008, 05:31:20 pm
Spa tech just left........great guy, great company, and I'm glad I'm backed by an awesome dealer who represents a great manufacturer...
Turns out that JET PUMP2 was bad.  He had a brand new pump in the van and ended up draining the tub, replacing the pump after many diagnostic checks isolating the issue to Jet Pump2, and finally refilling.  Once everything was completed, he did a nice thorough 1 month checkup on all the jet covers, components, etc, cleaned up the area, and went on his way.   I also had a chance to get a nice quick coat of GEL GLOSS on the tub, and around the water line area before the tub was refilled.
Two Thumbs up for a great dealer and great service.  Only regret is that they didn't bring a truck load of hot water to refill the tub........guess I'm waiting one more day to soak :D
Post by: spaman-- on March 05, 2008, 06:02:53 pm
I am amazed they don't have slice valves. It would have made it so much easier on you, the tech and your power bill. The corners manufacturers cut to cut cost are truly  absurd at times. Glad its back up and running. ;)
Post by: run1stride2nd on March 05, 2008, 06:07:10 pm
Yes............agreed.  I asked about that as well, and he said the same.
It is what it is.  Hopefully we won't need a slice valve long term.
Post by: Jacuzzi Jim on March 05, 2008, 06:34:02 pm
Another conviction to those that have not bought yet and are thinking about it.  Yes Lurkers and others hanging around I mean you!
 Doesn't matter what brand, they can all at some point have some sort of problem.  The dealer/manufacturer makes all the difference in the world!!!  ;)
 Glad they fixed you up!
Post by: run1stride2nd on March 05, 2008, 06:51:22 pm
Ya know, I did look at the big box tubs, and the "truck specials" that you find on the weekends, but............I ended up with the local dealer who I knew that I would eventually need a local relationship with.
My neighbor ended up with a Costco tub, and had some electrical problems from a storm that affected our area last fall.   He waited close to 3 weeks to get service on that tub.  He was bummed, so that actually played into our decision.  He also did all his own wiring (phone call after phone call to a family member that is an electrician in another state), moved the tub into position from the street, etc.  Too much BS for me..........I like to do it myself with lots of things (that I know about).
I buy "quality" sometimes at a premium on most everything I own, right down to the carbon fiber, exotic metals, and combination material bicycles that I race, and never have regretted the decision, and the after sales service that I've recieved.    I'm in sales and I'm also not the lowest price guy in our industry, but have some of the same customers for close to 18 years...............relationship, relationship,relationship.
I feel that we negotiated a very good price that I was happy with in the end, and so is my dealer, so he doesn't regret seeing me or my wife coming in the door.
One of the things that he mentioned early in the sales cycle was that my 2 young daughters would probably be spa owners one day as well since we were becoming spa owners.  I figure,  better to set a good example for them now with quality rather than seeing the old man working on the thing at night in the dark to save a few extra dollars.   We spend more time together enjoying the tub or any other product rather than working on it.  Hopefully, they'll look for a husband like me! ;)
........in the end, some who read this couldn't give a c%&P, but for those who do, make sure to figure out what you can "live with" for the next 15+ years before you make your purchase; both product and service relationship, the dealer is not just the supplier of your chemicals.
Done babbling, water is 70F, after 2 hours..........bummer.
Post by: Spatech_tuo on March 05, 2008, 07:01:23 pm
Wow, he got service in 3 weeks? He must have known someone!! ;) ;D
Post by: run1stride2nd on March 05, 2008, 07:05:23 pm
Yah, I could barely wait the one full day, can't imagine 3 weeks.
 :o
Post by: hottubdan on March 05, 2008, 09:55:48 pm
What I don't understand is why pump 1 also appeared to trip the breaker.
Post by: run1stride2nd on March 05, 2008, 10:15:54 pm
Since I'm not an electrician, or spa tech, I can't explain all, but it had something to do with the mV levels when and the "ground" block.  He had the ground disconnected several times and tried measuring some type of level, and it was always "0"
Like I said, I don't really understand that stuff, but after several tests, he was able to isolate that it was Jet Pump2 and the problem was gone after the replacement was installed.
.......maybe one of the techs can explain?
Post by: spaman-- on March 06, 2008, 05:40:06 pm
O.k I am not a tech but I play one on the internet. The reason that both pumps would trip the breaker is because on this spa both pumps are on the same circuit on the board when pump one is engaged on high. When pump one is turned high a short from pump 2 is detected and caused the breaker to trip. This of course would also occur when he tries to engage pump 2.
Post by: run1stride2nd on March 06, 2008, 05:52:58 pm
......show off. 8-)
Thanks for the explanation.    Water is ready!  FC is at 4.5, TA is at 120-ish, and Temp is 102F ......and water is like a botttle of spring water, no foam, no slow bubbles, just Sprite looking water!
I'm so happy I have tear's in my eyes!  :'(
Enjoy you're evening :)
Post by: Spatech_tuo on March 06, 2008, 06:08:48 pm
What I don't know is whether you had someone sit at your computer to type that or whether the response was e-mailed for you to simply copy/paste?
Post by: spaman-- on March 06, 2008, 06:27:43 pm
That my friend is the result of years of experience, skillful training, a 3 minute conversation using process of elimination to determine the exact part of the board that was picking up  said short, and another 30 seconds to determine the exact wire on the capacitor of the second pump that was causing the short in the first place.Whew! ;)
Oh and NOONE sits at my computer!
I tried copy and paste once and I had to use a razor blade to get it of of my monitor.
Post by: run1stride2nd on March 06, 2008, 06:36:26 pm
Thanks O-B-1.
That is about how the service call went as well.
......young pada-wan.
Post by: spaman-- on March 06, 2008, 06:38:11 pm
Not to under mind your theory but, a dirty would typically cause a lack of flow to a pressure or flow switch depending on the brand of spa and it would disengage the heater (to protect it from self destruction) and show a flow error on the topside, in this mode  the spa would not heat.It is not probable that a dirty filter would cause a trip of the breaker.  ;)
Post by: run1stride2nd on March 06, 2008, 06:41:36 pm
Filter is clean (like new).
It was a good first check, but not the problem as was figured out.
Post by: Vanguard on March 07, 2008, 12:54:22 am
But, you never know.  It was just a quick try before calling the dealer.
Post by: run1stride2nd on March 07, 2008, 06:13:05 am
Absolutely!
I was hoping for something quick to fix the issue so I could enjoy that evening.
Being very new at this, I figured it "could" possibly be something I had done wrong, unfortunately/fortunately, it wasn't
I alway enjoy, and appreciate any guidance from forums like this where people are happy to offer help.
Thanks.
