Original => Hot Tub Forum => Topic started by: Shanezam203 on March 01, 2008, 08:02:58 pm
Title: Should I buckle all 4 straps every time?
Post by: Shanezam203 on March 01, 2008, 08:02:58 pm
Hey Guys, I obviously have a cover on my tub, I am in and out of it at least once a day if not twice...
(I have the Spa Cover Lift installed)
Do you advise I buckle all 4 of the straps each time I get out of the tub, or what is your stance on that?
Thanks,
Shane
Title: Re: Should I buckle all 4 straps every time?
Post by: Vinny on March 01, 2008, 08:13:29 pm
My opinion on that is that if you don't have little ones running around or visiting then don't bother. My tub is a little sunken into the deck so a toddler may be able to lift it and fall in. If you have a tub that can't be gotten into without steps, it is a little safer than a sunken tub.
Since I don't have little ones, I only use the clips when it's windy out or I go away and then I lock the clips.
Post by: ndabunka on March 01, 2008, 09:27:14 pm
Thanks,
Shane
Why not simply use them every time?  It's not like they are going to wear out, right?  Better safe than sorry IMHO.  Who knows when some neighbor's kid is going to sneak over and try to use your tub.
Post by: Vanguard on March 02, 2008, 01:28:45 am
Because most torn straps come from someone who forgot to undo the back straps.  You undo the front ones and forget to do the back ones, lift the cover and, snap go the straps.
Unless you have a lot of wind or other reasons to strap them, don't worry much about it.
Post by: windsurfdog on March 02, 2008, 10:34:46 am
Vanguard's point about wind is excellent...the reason I make sure mine is secure up on my deck elevated 8' off  the ground.  If the backside of your spa is not in public view or your don't mind the look, I would suggest securing bungie cords to the deck/slab and connecting to the straps.  These would take care of securing it automatically.  This works well for me.
Post by: Richs100 on March 02, 2008, 11:35:23 am
The cover lift mechanism should be sufficient to keep the back of your cover securely on your tub.  I just use the front two.  In fact, my dealer intentionally shortened-up the rear two straps so they could not be used.   He said a lot of people forget they buckled the rear clips and rip them off when they use the lift to open the tub.
I get some pretty good winds where I am and have never had a problem relying on the lift to hold the rear of the lid down.
Post by: Vinny on March 02, 2008, 11:43:10 am
Hey I brought it up first!!! ;)
Post by: tony on March 02, 2008, 11:43:32 am
I essentially never use the buckles, but my spa is sunk into a deck and is extremely protected from the wind.  I stopped early in ownership when I opened the spa and forgot to unbuckle the back straps.  Luckily the part that screws into the cabinet broke and it was an easy fix.  If wind is an issue, buckle the straps on the front.  There are stories around of wind blowing covers right off.
Post by: Vinny on March 02, 2008, 11:44:11 am
I've had the back of my cover flip frontwards when I didn't lock them down.
Post by: Richs100 on March 02, 2008, 12:02:01 pm
Vinny:
My coverlift is a Covercradle II sold by Hot Spring.  I guess since the rear of the cover is directly attached to the lift mechanism, it can't lift up like yours did.   I hadn't thought about other lift systems.
(http://i132.photobucket.com/albums/q37/richs10/kw006.jpg)
Post by: windsurfdog on March 02, 2008, 12:08:06 pm
Indeed you did...my apologies for the oversight!  Excellent observation!
And, like in your later post, I prefer not to rely on my cover lifter to keep the cover on.  The bungies work extremely well for me and only need periodic replacement which is easy enough. 8-)
Post by: 96SC on March 02, 2008, 01:47:05 pm
The cover lift mechanism should be sufficient to keep the back of your cover securely on your tub.  I just use the front two.  [glow]In fact, my dealer intentionally shortened-up the rear two straps so they could not be used.   He said a lot of people forget they buckled the rear clips and rip them off when they use the lift to open the tub.[/glow]
My dealer told me not to use the back straps, too, for the same reason Richs100 told hm.  We have the HS coverlifter and our tub is in a fairly tree surrounded area so wind isn't a problem for us.  (Providing a wayward hurricane doesn't pass through).
Post by: drewstar on March 03, 2008, 09:23:18 am
Should you buckle all 4 all the time?
Yup.
it's there for safety, if a dealer told you don't bother, because they may rip or it's a pain, then that dealer is an fu#%$@!ing idiot.
In addition to saftey and liability, the buckles also keep the cover down in high winds, keeping in heat and keeping out debris.  A cover snuged down will also keep in heat.  A loose cover will cost you money.
Now if you hate to unbuckle the back (- and I do.  I hate it. Espically in the winter), there are a couple of things you can do:
By a huricane strap from the good folks at RHTubs.   Mount the back buckle low on th back of the spa.  this way, you wont have to unbukle the back latches. Simple. I did this on my Caspian and it worked great.   I think there are still picks on Docs Website of my TR Caspain with the strap mounted this way.    http://www.rhtubs.com/store/hurricane-strap.htm
Or you can buy cover lifters (such as the Pro lift II).  This is what I have on my Geneva and it's a topnotch cover lifter.  Because the back of the cover lifter mounts to the actual cover, there is no need for back buckles. It's fantastic.
At the very least, next time you are at your dealers, pick up a couple sets of replacement buckles. They cost under 10 bucks. They're great to have on hand because you will snap one.  Trust me.
 8-)
Post by: dax on March 03, 2008, 10:21:02 am
Straps on the back of my cover must be longer than most.  Combined with the lift, I don't have to unbuckle the backs ones.  My cover lifts up and drops back without having to unbuckle.  Glad it does because one of us would definitely forget about them.
I also rarely buckle the front ones.  The cover fits snug, and I haven't had any issues with wind.
Post by: rick_in_cleveland on March 03, 2008, 10:23:32 am
The only time I have  buckled up is when we are gone out of town
Post by: Shanezam203 on March 03, 2008, 10:29:51 am
Thanks guys for the replies, I really appreciate it.  I will try to do all 4 buckles especially when I will be gone for a week at a time.  (I travel a bit for work)  But when I am getting in and out during the day, I willat least try to do the front 2.
I also believe it is in a good area behind my house, and with the cover lift in place on the back, the wind is not going to get to it.  But I will do the front 2 for added security, thanks all for the replies.
Shane
Post by: Bonibelle on March 03, 2008, 10:35:12 am
I also have a covermate lifter and I have never unbuckled my back straps. I ALWAYS keep my cover buckled shut. I figure the cover clips are there for a reason..so I use them. If I go away for any period of time, I lock the cover clips. It only takes a few seconds to lock and unlock..I have a pretty secure back yard and the tub is only a few feet from my back door, but I would not risk a child getting easy access to the tub. The cover lifter makes removing the cover easy and the steps give accessability...too much liability for me...
Post by: Mike Blute on March 03, 2008, 10:37:12 am
Shane
That's what I do. If I am traveling for MORE than a week,then I think it's important to buckle it up nice and tight. However,  if I am going to be away for less than a week, it is not neccesary to snap all the buckles. Why bother? It's a real pain in the backside!
Post by: Brewman on March 03, 2008, 06:20:02 pm
Hi Mike Blute.  Nice of you to drop in on us.
What is new in the "specialist" world?
Post by: Mike Blute on March 05, 2008, 01:26:28 pm
Mr. Brewman,
Things are just red sweater dandy in the specialist world. Things have never been busier! Never!
In fact, we have been so gosh darn busy, we still have not had the time to update the UL listing page on the website. Darn it!
We have been too busy to even build a spa! Can you believe it? Jim did try and taunt Chas a while ago, without success, and Jim also ranted about capitalism and the evils of the free market, but no one pays any attention any more.  At night I can hear Jim sobbing quietly to himself.
Sandy has taken on a second job modeling for a new facial hair removal product.
The web site is busy! In fact, we just ran a poll.  It was a smashing success! Smashing! We kept the poll open for an entire month and averaged just less than one vote per day!!!! That is a new record for our site! Whooo!  We might have to buy a new server to keep up with the traffic!
Post by: Zep on March 05, 2008, 10:59:11 pm
I don't buckle mine all the time
but I would if I didn't have locks on front & back gates
