Original => Hot Tub Forum => Topic started by: solo on December 04, 2007, 10:21:02 am
OK...my values are in spec, but getting close to the limits.
ph= 7.2
TA approx 120
Tests were done by strips, so could be off.
However, what would you do if your ph was low but TA was high?
Use sodium carbonate, not sodium bicarbonate.
ph= 7.2
TA approx 120
Welcome to my (normal) world. PH = 6.8, Alk = 160 (or so)..
The ONLY way to get this back in sync is to first lower your alk and then use sodium CARBONATE, not bi-carb.
