Original => Hot Tub Forum => Topic started by: anne on September 29, 2007, 12:13:35 am
Title: What happened??? water/electrical problem???
Post by: anne on September 29, 2007, 12:13:35 am
I went outside tonight to top off the tub in anticipation of a nice late night soak......I then FORGOT about the hose, and it ran for a solid 2+ hours. The water in the tub is pretty cold, so I assume that almost 300+ gallons spilled (my tub is 390 gal). The scary thing is that the tub is OFF. NOTHING. I tried flipping the switch in the main box, and the resetting GFCI in the tub box, but it wont let me reset. I assume that water got places that water should not go......but now what????
I'm going to wait until daylight, but I'm worried. I know that we have had some heavy rains before with no such trouble. Is it possible that water could get in the control panel on top? That worries me too......
What should I do?
Title: Re: What happened??? water/electrical problem???
Post by: mattNY on September 29, 2007, 01:23:08 am
I just got in from my soak, I hope you get this all set tomorrow anne.  I've had mine overflow quite often when I have too many people in there, but it's never caused a problem like this.  Maybe after a night to "dry out" it'll be fine, but if not, you could give your dealer a ring in the morning and ask, right?  Of course, I'm sure you'll get 15 other responses by morning :)
Post by: anne on September 29, 2007, 01:43:10 am
thanks, Matt- that is what worries me.....I haven't had this much overflow before, but still..... :-/
I'll see what happens in the morning.....
Post by: Pathfinder on September 29, 2007, 02:28:34 am
Even with your water over flowing,  water should not be able to get in your control pack if it was built properly.  The only way on an Arctic is if the seal between the shell and the cabinet isnt air tight or the panels are not air tight.  Check to see if your control box has water on it. If so open it up put a hair dryer on the control board for a few mins  then let it sit a while. It should fire up after. Make sure you dont have any air locks as well.  If water did get into your system and the tub wont fire up  you should be covered under warranty. As there would be a defect in workmanship if water can overflow in the tub and get into the spa pack.
Post by: tony on September 29, 2007, 08:38:59 am
What should I do?
This happened to me before.  Its kind of a sinking feeling when you realize you forgot you were adding water to the spa. :(  My spa didn't trip but I would give everything a chance to dry and see what happens.
Post by: Vinny on September 29, 2007, 09:01:40 am
Check the GFI on the tub. Overflowing water should have no impact on any tub. I also have been in the tub with one too many people for the amount of water I had in the tub and had it overflow. 10 gallons or 1000 gallons shouldn't make a difference.
It is possible that the seal around the controller did break and let water in. If that's the case I would think this is a warranty problem. I wonder if there is a rubber gasket or does the factory (any factory) use silicone from a tube to seal it; it shouldn't matter as long as enough sealant is used.
Hopefully by the time you read this all is well.
Post by: East_TX_Spa on September 29, 2007, 11:12:07 am
Most spas are waterproof.  Hopefully yours is as well. :(
Termie
Post by: hottubdan on September 29, 2007, 11:22:46 am
Could be unrelated.  Often we jump to conclusions that one thing led to another.  Maybe the spa shut down and was cold before you overflowed it.
My tech told me he did a service call on a 110v spa that had no power.  He proceeded to plug it in.
Embarassed homeowner hadn't checked the plug.  After all, she didn't unplug it.
Post by: anne on September 29, 2007, 12:14:05 pm
There does not appear to be any leaking around the control panel on top, but when I opened the cabinet to get to the electrical box, there was some standing water in the bottom of the cabinet around one of the pumps. The box itself seems unaffected,  but it was humid in the cabinet, so could that seep into the electrical stuff? Or would water pooling around the base of the cabinet do it?
In hind site, I felt like I had been adding water a lot more lately......maybe there has been a little leak? I just dont see how this water flowing over the top could have gotten in there. Everything seemed tight and sealed.
Dan, the tub was running when I went out to stick the hose in.
Post by: hottubdan on September 30, 2007, 11:15:15 am
So, is it running?  Is the failed spa the source of your crankiness? :-/  Don't you wish you had bought that Hot Spring after all?  Then you could have Term advising you to get an AK47 and shoot your hippie neighbors when they come to visit you in your spa. ;)
Post by: D.P. Roberts on September 30, 2007, 06:51:44 pm
I did a similar thing once. I had a dozen or so college buddies in my parents' spa one night. It overflowed when the thirteenth person got in, and the tub shut down. Completely. I was sure I had busted it.
So, we went and woke up my Dad (who likes his sleep). He crankily got up, inspected the spa, and discovered that the timer had just shut off (this was back when all tub functions, including pumps and filters, were controlled on timers). He went back to bed (grumpily) and we got back in the tub (sheepishly).
Post by: anne on October 01, 2007, 01:22:17 am
Not running yet. They'll call tomorrow. It is not a big priority at the moment, so I'm just dealing with it. My 13 year old dog is really sick, and I'm up with him abot 4 times per night, the kitchen is in the middle of a remodel, so it is just a room of dust and drywall, and the washing machine broke, and my dealer is 2 hrs away, so I'm just putting the tub in the background right now. I dont wish that I had bought a hotspring, but I do with that I had a dealer as local and as helpful as you!
D.P.- I wish that were the case here! The cabinet had a few inches of water, but I think I already had a small leak, and the "cherry on top" may have been over filling.
I do find it alarming that this *could* happen just from over-filling......
Post by: Tom on October 01, 2007, 02:00:12 pm
They'll call tomorrow. ...I do wish that I had a dealer as local and as helpful as you!
Sounds like you had quite a weekend... and not able to soak your cares away.   It sounds like your dealer will be working on it soon.
We are working to expand our dealer network, honest!
Post by: Dipstick on October 01, 2007, 04:07:39 pm
Termie
Sorry but unless your spa is made from solid steel or glass it is not waterproof. In all other materials the molecules are not tight enough to stop water but as in acrylic, plastics... is does greatly slow it down. ;D
Post by: LtDan on October 01, 2007, 09:23:56 pm
Makes me wonder how all them fiberglass boats are still floating  :)
Post by: MostlyLurkingGal on October 01, 2007, 11:27:34 pm
Well that does it! I'm getting glass toilets!
Post by: anne on October 02, 2007, 02:05:15 am
Update: They called late afternoon, and left a message for me. (I did not get in until after 7pm, so I was a bit irritated that they did not call the cell phone # I left.)
Here's some history to help this make sense: when I bought the spa, I did a lot of reading here for education. Because of that, one of the questions I asked my dealer was how long he had been in business, and was he sure that he'd continue being an Arctic dealer long term, since I saw 5 years ahead of potential warranty calls. He swore up and down that he loved Arctic, and planned to be with them "a long time"......and then not 2 months after I took delivery of my spa, he quit selling Arctics, and moved on to Phoenix spas!!!!!!! Un feakin' believable! And you *know* that was not a business decision made overnight! I shall now refer to his as Mr. Wanker.
 So now "my" dealer is not the one I bought my spa from, but he is now the closest, and about 2 hrs away, and they came out to install my ozone after Mr. Wanker went to the dark side. It sounds like they *may* be able to come out later this week, but if not, it woudl be at the end of the month. Yep.....the end of OCTOBER!
I understand that this is not their fault that Mr. Wanker was a lying piece 'o feces, but I also think that waiting a month is unacceptable. Am I asking too much? It is finally cold enough to soak, and considering things lately, I could REALLY USE A TUB!!!!!! I would think that Arctic would have to compensate this other dealer for his time to make things right for both of us, and find a way to make that happen SOON!  Am I wrong?
Post by: Bama on October 02, 2007, 07:10:12 am
Anne,
I'm sorry to hear about your tub troubles....however, I'm more concerned with your furkid!  How is he...she?  I love dogs, especially chow chow, shih tzu, schnauzer and pugs.
I don't work for a dog rescue, but I pick up stray dogs off the streets when I see them.  I specialize in chow chows.  The local shelters call me when they have a chow and I work with the chow to help he or she become more adoptable.
Unfortunately, it is a breed that is very mistreated.
I hope you get your tub fixed soon.
Just a guess here, but how did you get the water back to normal level?
Could one of the pumps need to be primed?
Post by: anne on October 03, 2007, 01:43:06 am
Thanks, Bama. My dog, for the moment is sort of OK, and at least comfortable, but it has been a heck of a week. He's 13, and has been my friend, companion and self appointed protector for that whole time. He developed severe spinal problems this week, and is currently unable to use his back legs, incontinent, and has some other medical issues that complicated everything. As of today, we *think* and hope that what he has is a vascular condition that will slowly correct itself, but for now I'm getting limited sleep, taking him to work with me, doing physical therapy and trying to lift/carry a 75lb dog around, doing lots of laundry, and it'll be 2-8 weeks before we'll know for sure if he'll improve, and then up to 4 months for full or at least mostly complete recovery. I was fairly convinced before his MRI that I was going to have to consider putting him down very soon, and though I deal with that sort of thing everyday, it is from the semi-objective position of the clinician, not the agonizing pet owner. We're still not sure he'll get better, but I'm doing my best to think positively, since he absolutely locks on to all of my emotions.
So you are right, the tub is just gravy, but the timing stinks, cuz my back hurts! Whatever.....today I think my furry buddy will be with me for a bit longer, and for the three previous days, I was feeling like I had already lost him.
As for rescue work, good for you! Chows can tend to be aggressive and a little unpredictable, but raised and treated well, some of the sweetest, most wonderful patients I have ever had have been chows. It is hard to find rescue groups who will really embrace them. Keep up the good work!!! And thanks for your thoughts.
Post by: Bonibelle on October 04, 2007, 09:19:11 pm
Anne, I just have to ask...did you test him for Lyme?  It is moving across the US unbelievably fast...Maybe you wouldn't look for it since it isn't typical in your area. When my dog first got it, she couldn't walk, she would just sit and cry. Since I had it, I recognized the symptoms right away...just a thought Dogs do really well with Doxycycline and in two days, she could walk, go out to do her business and within a week, she was running again...I guess I have Lyme impregnated in my brain!
Post by: anne on October 05, 2007, 02:17:29 am
Thanks Boni, but no, this is spinal damage, either degenerative or caused mini clots, so to speak. He is non-painful, but he is basically a paraplegic. I am lucky enough to have considerable diagnostic options available to me, but I guess unlucky to have him dealing with such an unusual and quite possibly irreversible disease.
