Original => Hot Tub Forum => Topic started by: bankrbill on September 30, 2007, 12:18:56 pm
Hello once more.
Does the Hot Spring Aria really cost less to operate than the Coleman 481 or the Jacuzzi 355? The Hot Spring dealer here in Indy insists that the Aria will cost less each year in chemicals as well as electical costs.
Thanks in advace for your time and opinions.
Bill
This is a generalization.
All quality tubs will cost approximately the same, the difference may be $10 a month if that in electricity. There are people around with all 3 brands in cold climates and I can't remember anyone who said they have outrageous bills other than a problem.
Chem costs are the same except a smaller volume tub uses less chems to get to the correct range. If you're looking at a 300 gallon tub vs a 500 gallon tub then yes it will cost less in chems.
Hot Spring publishes the cost of their spas conducted by 3rd party testers. You can see this in their brochure. They also base it off of different temps from throughout the country.
I've seen other manufacturer's operating costs, but they base it off of running the tub in a 60F or 70F room, so make sure you're not fooled.
As others have said, I doubt it's true for chemicals. That will depend not only on the size of the tub, but also on the bather load (and how dirty those bathers are) ;).
As to energy, maybe. I don't believe anyone has done an independent, head to head comparison test.
Hello once more.
Bill
Don't buy from that HS dealer. I don't like their aproach to sales just from the above post. All they had to say is "we make/sell a very effecient spa" and leave it at that. All the rest is hoopala.
Hello once more.
Bill
Simply ask for documentation that backs up their BS....ahhhh statement....
