Original => Hot Tub Forum => Topic started by: sonofsail on August 09, 2007, 10:39:42 pm
I am very close to buying a hot tub. I have done lots of research and wet tested both. Is there any significant difference between these brands in terms of quality?
thanks, sonofsail
thanks, sonofsail
No. They are made ot the same factory. Many of the components are the same. I would choose the one you are most comfortable with from the dealer you are most comfortable with.
Thank you so much for your reply. I plan to go by both places tomorrow to see what kind of a deal I can get. The Sundance dealer has been around for many more years than the Jacuzzi dealer so I am leaning that way. We really like the Optima.
I have owned an Optima for two months. I am very happy with the tub.
What's the verdict?
Sundance Optima :) No stereo.
Got what I think is a good deal with a reputable dealer who has been in the area for at least 20 years.
Arrival in about a month.
(http://i144.photobucket.com/albums/r165/tileman_photos/CONGRATULATI_12428.gif)
Thanks Chad!!!!!!!!!!!!
I'm pretty fired up about it. It will be a long month waiting for it.
What chemical/disinfection system would you recommend?
Chlorine or bromine? Ozone? yes or no?
I am very familiar with water chemistry (large pool manager for 35 years and a chemistry teacher)
I am familiar with chorine use but have no experience with bromine use.
What type of stuff do you use for testing? ;) ;D
Hot water behaves differently than cool water.
Bromine and chlorine are about the same as far as ease of use except that bromine seems to need fussing with in the beginning before you can go on autopilot.
Ozone - Flip a coin! ;D Some love it some don't. If you got to pay $$$$$ for it - it just ain't worth it!
My personal preference is the Dichlor version of chlorine, ozone and silver cartridges. That is the easiest method and you get the least amount of smelly chlorine as long as you keep the balances correct.
If it was cool water, I would be all over it.
I'm most familiar with chlorine systems so I will most likely go with dichlor.
The ozone system can be added without additional expense if I want it (part of the deal) so I will probably get it as long as there are no down sides to using it.
Forgive my ignorance but what is the purpose of the silver? I assume it complexes and removes some undesirables. Or is it used as an algaecide? (sp)
The TC, CC and FC concepts are very familiar and I will have no problems oxidizing each week (knock on wood).
I have read that dump and fill is a good idea after the first month of a new tub. Any comments?
Thanks for the help. This is a great site and you all are very kind to assist a newbie.
If the ozone is free, go for it. With the silver and ozone, you can use less chlorine.
Keep away from chlorine tabs! Those are for pools.
thanks dan
Here is my take on ozone and/or mineral cartridges with dichlor. I started with ozone, Frog mineral cartridge and dichlor in my 2002 Optima. I switched to ozone, SunPurity Nature2 mineral cartridge and dichlor at about my third year of ownership. I had a small issue with my ozonator last fall, so I removed it and ran without. This spring I stopped using the mineral cartridge and now use just chlorine.
In my experience, ozone and minerals definitely help with water maintenance, especially if you are not a daily soaker. It takes more chlorine and more dilligence to keep your water clear without them. I think using both ozone and minerals works best rather than just one or the other with the chlorine. Daily soakers get less benefit because they add chlorine on a very regular basis.
I will continue to use just chlorine at this point. I believe ozone does a number on the spa pillows and other plastic parts and I have been able to keep my water in good shape without spending the added dollars on the mineral cartridge. I do, though, reserve the right to change my mind. ;)
Silver is a slow acting bacteriacide. It needs a companion sanitizer because soakers in a small body of water will introduce more bacteria than the silver can handle. It does not kill other bugs that may infest water such as viruses. Silver helps keep water clean in between soaks after the primary sanitizer does its job.
My mentors have already chimed in and gave you great advice. :)
Fwiw, I use ozone, N2, and dichlor and have never had even a hiccup with my water. Being a chemistry teacher, I don't think you'll have any problems at all. You are probably already familar with dpd test kits as well. The most popular one used by us is the Taylor k-2005. It's a staple in my opinion for any spa or pool owner.
The 03, N2, and dichlor routine is very user friendly. Simply install the mineral cartridge as directed and dose with dichlor to 3ppm after ever soak and shock once CC reaches .2 - .5ppm with mps(nonchlorine shock).
Once you get more familar with your spa water and depending on your average daily bather load, you will be able to extend the periods between doses of dichlor. For instance, when I first got my spa I played it safe and always brought my FC to atleast 3ppm after every soak. Now I can go up to a full week soaking by myself everyday with just one 5ppm dose of dichlor. The O3 and N2 really do work. One other thing that I feel plays a huge part in keeping everything in line and help lower your tubs dichlor demand is to shower before your soaks. Also, I try and keep my pH between 7.2 and 7.5 b/c it allows the chlorine to become a higher % of it's killing form(hypochlorus acid), but you probably already new that. 8-)
Thanks so much for all the great help. I am familiar with a lot of what has been written but being new to the tub scene, I need all the help I can get. It will be a few weeks before the tub arrives. I will post pictures once it is here.
Tony, how do you like your optima?
I love it. It turns five years old on Wednesday. It has been all I expected and more. As I've been mentioning, the spa has been literally abused the past couple of summers and doesn't even hiccup. The other three seasons are much more sane, but the spa gets used almost every day. If I were buying today, I think I would make the same chloice. Its the perfect layout for me.
Tony
I looked around for several weeks and went back and forth between a lounger and a non-lounger. I am glad to hear positive things about the Optima. As I mentioned earlier, it will be a long several weeks waiting for it. The fact that it is so hot here right now makes it a little easier to bear.
Thanks for your advice. I'm sure I will have more questions when it gets here.
Congratulations. Your going to love your spa. The Optima is Sundance's best selling spa. Its been around for a long time, with updates, and is tried and true. I had to wait about eight weeks when I ordered mine.
