Original => Hot Tub Forum => Topic started by: Nitrousman on July 20, 2007, 12:29:41 am
I need a wiring diagram for 2003 Dynasty Excalibur tub so I can try and figure out if the pumps bad. Thanks.
If the previous owners chems were bad check to see if there are deposits built up where the seal is. It just might be the seal going. If its like most spas the wiring schematic should be on the inside of the front panel of the spa pack. The pump wiring should be on the pump.
OK, I'll check that tonight. I know the jets have some calcium buildup on them from the well water. THanks.
