Author Topic: Proper Chemicle Method  (Read 3806 times)
nicker
« on: November 16, 2006, 09:33:48 am »
Well for two years no problems with my ways but lately my tub just isn't right for some reason.    Right around the 2 mth mark my water feels funny, tub walls a little slick.  TDS seems high for that short of time.
What is this method that most people go by and where can I find the details so I can compair what I am doing differently.  I hear of people talking about it all the time but fo the life of me I can't remember the name.
thanks
jfish63
  • 2002 HS Grandeee
Re: Proper Chemicle Method
« Reply #1 on: November 16, 2006, 10:13:24 am »
http://www.rhtubs.com/bbs/FAQ.htm  There are 2 methods listed. I go by the vermonters method.
« Reply #2 on: November 16, 2006, 10:37:46 am »
I also pretty much go with Vermonter's method.
And keep Chas' rule in mind-
 The simplest and least expensive solution to bad water is new water.
I know that's not a direct Chas quote, but that's in essence what he says.
nicker
« Reply #3 on: November 16, 2006, 10:55:50 am »
I realize that in most cases the cheapest way to clean up your water/tub is new water. I was just curious as to why my water is only lasting the 2mth mark lately when use/chems etc has not changed.
The only thing I really do different then the vermont method is I use MPS to shock.  now the MPS I use does have some sanitizer in it.  I really like it but I wonder if I could get away with a by weekly shock.  I may try that.  Or at least test my water to determine if I can get a way with a by weekly shock.
Does anyone else shock by weekend and hows it work for you?
« Reply #4 on: November 16, 2006, 11:39:55 am »
"Water is the cheapest chemical you can add to your tub" I think is how it goes.
And drewstars add on is....
....Unless it's -10 degrees outside  ;)
« Reply #5 on: November 16, 2006, 11:42:50 am »
nicker, as far as shocking less,
How often are you using the tub, and how many folks are in it?
I kinda go with a 10 bather/use  rule.   one person using the tub every other day or so, then sure 2 weeks works for me.
2 people every day? Once a week.
10 people in one day? Shock the next day.
I run 03 and use dichlor and have good results.  YMMV.
nicker
« Reply #6 on: November 16, 2006, 12:50:51 pm »
drewstar typically its me using at least every other night and on weekends two of us at least one night.
Maybe its the brand of chemicle I am using.  My Alk is a different MFG, but that is about it.  But I would assume there is not much difference in Alk and PH chems is there?
« Reply #7 on: November 16, 2006, 01:29:05 pm »
I'm far from a chem pro Nick, and like you for 2 years no crazy problems. I've stuck with the same chem brand and dist, so  I can't say if that would make a big dif. I don't think the Alk and PH could be significantly different. (Unless the active % is different?) Check the lables.
I assume the clarity is fine?
You know, they say the 03 doens't last much longer the 2 yrs, but I would think you'd see a clarity issue if that started to die on you.
I'd dump and run. Maybe a one time fluke?
As far as shocking, with your use, I'd move it out to 10 days or so and see what happens.
« Last Edit: November 16, 2006, 01:30:05 pm by drewstar »
tileman
« Reply #8 on: November 16, 2006, 02:40:27 pm »
According to Vermonter, MPS has NO sanitizer in it.
« Reply #9 on: November 16, 2006, 05:00:24 pm »
But they make MPS with dichlor in it....I think it's called, like, enhanced shock or something.
tileman
« Reply #10 on: November 16, 2006, 05:08:01 pm »
I did not know that. :-? I wonder if they put enough in it to actually get a "shock". Or is it just a normal dose? I'd like to learn a little more about that "enhanced shock".
IDW
« Reply #11 on: November 16, 2006, 07:54:16 pm »
A ozonator stops working after about two years
tileman
« Reply #12 on: November 16, 2006, 07:57:59 pm »
What are you commenting on? :-?
IDW
« Reply #13 on: November 16, 2006, 08:02:10 pm »
The original question
tileman
« Reply #14 on: November 16, 2006, 08:10:05 pm »
Sorry, it's just alot easier when you click the quote icon, when multiple people have posted.
