Author Topic: Routing Electical in Sundance Maxxus  (Read 2926 times)
Johnny D
« on: May 24, 2007, 10:28:28 am »
Planning on getting a Maxxus and noticed that the electrical is designed to enter thfrom the outside on either of the front two corners.  I'd like to come up from underneath and stub up a piece of conduit when I plan the pad install to eliminate seeing it.
Any problem coming up from underneath that I should be aware of?Thanks in advance.
jd
cburk0677
Re: Routing Electical in Sundance Maxxus
« Reply #1 on: May 24, 2007, 11:29:46 am »
This needs to be moved to the main forum as it is 100% hottub related.
Enjoying SpaTopia in my 2006 Hotspring Vanguard
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #2 on: May 24, 2007, 12:32:52 pm »
As long as you open up the Maxxus you are going to get and do the correct measurements, there are no issues with coming up through the bottom.
Campsalot
  • Sundance Maxxus Super Tub
« Reply #3 on: May 24, 2007, 11:13:13 pm »
 have a Maxxus and also came up from the bottom.  I came right through the bottom frame member on the right hand side.  No probs and worked great!
« Last Edit: May 24, 2007, 11:14:47 pm by Campsalot »
Johnny D
« Reply #4 on: May 25, 2007, 12:13:58 am »
Thanks, Will have to stop by the dealer and see exactly so I know where to stup it up before I set up the patio.  On the other hand having it come up the side has its advantages.
Thanks for responding
