Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Original
HELP !!!!!!! Water change and now nothing
« previous
next »
Print
Pages: [
1
Author
Topic: HELP !!!!!!! Water change and now nothing (Read 2227 times)
jgirvine
Junior Member
I love YaBB 1G - SP1!
on:
August 22, 2006, 08:41:26 pm »
Have a D1 Triad.
We drained it to do a water change yesterday. Filled it back up with water. Husband did not tell me about opening the air line(
) now nothing is happening. Can here the motor, but getting nothing else..... any ideas as to what is wrong, and what I need to do?
Logged
on:
spaman--
Full Member
Hot tubs are not for soaking, they are for selling
Re: HELP !!!!!!! Â Water change and now nothing
Reply #1 on:
August 22, 2006, 08:47:02 pm »
ok heres what ya do. If you have a dinerter valve on the spa loosen it or them til the air blows out , or on the pump there should be a little black knob loosen it til the air bleeds out.Loosening the diverter valve will do it.
Last Edit: August 22, 2006, 08:54:16 pm by spaman_dot_com
Logged
-SpaMan~
Ultimate Member
Reply #2 on:
August 22, 2006, 08:49:34 pm »
It sounds like an air lock.
I think D1 tubs have circ pumps and diverter valves - here is what my dealer told me to do if I ever get an air lock - turn the tub off and open up the diverter valve ring on top of the tub. Listen for escaping air.
I have never had a bad air lock, I have had a little one and turning the tub off and on a couple of times along with turning the therapy pups on and off cleared it (saw bubbles).
Next time you refill, it is recommended that you take the hose and stick it in the filter hole - it forces the water into the pump and eleiminates the air.
Hope this helps!
Logged
Garyjr
Full Member
Let's SunDance!!
Reply #3 on:
August 22, 2006, 09:02:26 pm »
I just changed my water this afternoon and had the same thing happen as Vinny described. Pump 1 would turn on a second and back off. Luckily after cycling it on and off about 3 times, it blew the air lock out and water starter flowing.
Jr
Logged
hottub.pool_boy
Full Member
New England's oldest HotSpring Dealer- 1983
Reply #4 on:
August 22, 2006, 09:13:00 pm »
you guys are good!
Last Edit: August 22, 2006, 09:13:14 pm by hottub.pool_boy
Logged
jgirvine
Junior Member
Re: HELP !!!!!!! Water change and now nothin
Reply #5 on:
August 22, 2006, 09:39:14 pm »
Got it, had to put the hose down the filter hole, wrap a towel around it to seal as best we could, then turn the water on, saw air bubbles just blow out. Thanks for the help. Really appreciate it.
Logged
obi wan
Full Member
you're just jealous the voices only talk to ME!
Reply #6 on:
August 23, 2006, 12:41:02 am »
whats that about 75 virtual dollars for the virtual service call??
seriously though,
this is a great example of why this board can be so good. graet feedback right away, and BAM, problem solved....
Logged
Reply #6 on:
Print
Pages: [
1
« previous
next »
Original
Jump to:
=> Hot Tub Forum
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Take 42
