Author Topic: Today's the day!  (Read 5244 times)
autoplay
Today's the day!
« on: May 13, 2006, 09:16:29 am »
It's been almost 6 months,since we used our spa. Our spa was moved so the pool deck could be redone.
With that said,what should I do as far as prepping it,to get it back in operation?
Thx,
Rich
Today's the day!
Re: Today's the day!
« Reply #1 on: May 13, 2006, 09:37:34 am »
Rinse it and empty it before you cap the drains and fill it up. This helps get out any bad water which may have been left behind.
Then follow your normal filling stuff: fill and balance, but be sure to give it a good strong dichlor shock - I would say that two ounces should be sufficient - and let that run through everything by moving diverters and such.
If you had to do anything special when the spa was delivered new - as in priming pumps by opening drain valves or loosening pump unions keep those steps in mind. Assuming you had to tilt your spa to move it, you may have to repeat those priming steps or not.
And then get the thing hot and get in! Be aware that rubber duckies which have been out of water for than length of time may be crabby at first.
autoplay
« Reply #2 on: May 13, 2006, 11:51:25 pm »
Thx a ton Chas!  I did as you instructed,even drained it once after agitating all the water for an hour.
Crystal clear water!!
Guess I'll keep this spa for a few more years ;)
Ronald5599
  • HS Envoy installed May 5th - Very frustrated
« Reply #3 on: May 13, 2006, 11:59:24 pm »
Auto: You have a beautiful back yard area. Everything looks great. What part of the country do you live in? Good luck with getting back into the tub. - Ron
autoplay
« Reply #4 on: May 17, 2006, 07:32:47 am »
I live in Sarasota FL.
Here's a few more pics of spa etc after move.
« Last Edit: May 17, 2006, 07:34:53 am by autoplay »
Zep
  • Cal Spas SQ92 Dallas-Texas
« Reply #5 on: May 17, 2006, 09:38:26 am »
Nice atrium.
Great pics.
Know you will enjoy it.
East_TX_Spa
    • I Love My Spa
« Reply #6 on: May 17, 2006, 10:01:40 am »
That looks really nice autoplay! :)
Terminator
Skellman
  • There's more horses asses than there are horses!
« Reply #7 on: May 17, 2006, 10:24:15 am »
Autoplay,
Do you have a section of the house I can rent and move into? ;D ;)
What a crib! Outrageously nice! :o :o
« Reply #8 on: May 17, 2006, 10:25:19 am »
Looks nice!
I noticed that you moved the two closed-face rotary jets out of the back of the recliner. Did you put them somewhere else or just dump them?
« Reply #9 on: May 17, 2006, 12:24:57 pm »
Auto...
That's a stunning set up you have! Enjoy it good health!  :)
DoubleA
  • 2006 Caldera Tahitian
« Reply #10 on: May 17, 2006, 01:17:34 pm »
I especially dig the nice looking Caldera spa you have there.
autoplay
« Reply #11 on: May 17, 2006, 04:08:04 pm »
Looks nice!
Chas,I know what you're referring to/thinking.......
The 2003 Caldera Geneva Utopia didn't have the closed rotary jets.  I did see em installed on the 04's on up. The difference too with the "versa-sauge" jets between the 03 and on up is.....the valves on the 03's are built within the jet itself,the 04's on up,the valve is controlled on the outside ring of the jet housing.
I did switch out if I recall,20+ euro jets,with the euro-pulse/spinnin jets.
I think I bought a few of em from you Chas :)  It was either you,or Bruce,from Hotsprings on the east coast here in FL.
As far as renting out a room,we do have a spare bedroom,all I require is that the female staying with you is at least a 7...and will use the spa(using a bikini naturally) at least every other day ;)
« Last Edit: May 17, 2006, 04:10:05 pm by autoplay »
East_TX_Spa
    • I Love My Spa
« Reply #12 on: May 17, 2006, 04:13:17 pm »
