Dynasty was one of the many spas I wet tested. Here's an excerpt from my wet test report at
http://www.members.cox.net/duffman471/Spa_Wet_Testing_Analysis.htmI wet tested the Excalibur 5000 Renaissance, and the Neptune Poseidon
Here are the features I liked: a) There was good (not great) balanced power in the 3-pump model, but I liked the feel of the jet on the Poseidon much better. I would not choose Dynasty for myself, but I think the 2-pump Poseidon could be a great spa for those who like a very comfortable, but less intense jet package.
On a number of the seats, and especially on the lounger, the Poseidon has a great little jet that is made up of about a dozen tiny spouts. It did not itch or sting at all. I would have to say they felt “relaxing.†The 3-pump did not seem to have these jets.
b) The foot jets on the Dynasty spas include a large, multi-spout design similar to those in Master Spa LSX/LS2X. I think this style feels great. It’s also quite a different feel than every other type I have tested.
c) For the models with the lounge, the regular seating has about the least sculpting I have seen on any other spa. Despite the appearance of a lip between seats in the pictures, the large corner seat was specifically designed to use either side seat like a 2nd lounge. The large radius in that seat offers some interesting jet applications for the arms and shoulders.
d) I found the headrests on these spas to be very comfortable.
Here's what I didn't like:a) You might find it comfortable, but I was just unable to keep from floating out of the lounge seat. Also, the lounge design might be too small for people over 6’ tall. The reason I say that is that at 5’6â€, my feet were reasonably close to the end of the leg indentations.
b) If you look at the pictures you will see a lot of diverter valves with triskelion-like shapes. I really didn’t like these at all.
1) First, there was no way to tell what the setting was by looking at them.
2) There are so darn many of those knobs and none of them are marked in any way. The large ones are diverter valves, while the smaller ones are for air, waterfalls, or water spouts (little clam shells open up and a stream of water shoots a 1-2 foot arc into the spa). Anyone could get used to this setup but I had a very hard time figuring out what everything did.
3) On both spas, at least one of the diverter valves made a vibrating, almost grinding sound when adjusting the setting. Perhaps the valve was just loose in some way but the source was definitely the water pressure against the diverter valve.
