Welcome to our forum.
Bosco - I agree completely with you regarding the arm rests. Â Sure you're arms want to float, but having the arm rests absolutely gives us a place to put our hands rather than just floating about.
The heater is a 5.5kw heater (however since the heat from the pump is used to heat the spa this heater rarely comes on)
Personally, it was the arm rests that were an important influence in our decision. Since I am the kind of guy who cannot leave his hands underwater (shrivel up fast), I needed something to rest my elbows on. The open-bench style seating reminds me of my old pick-up truck while my new contoured tub is more like my captain's chairs in my new ride.Jc
I have something that I would like to throw-out there for arguement's sake. The statement:...causes much grief and friction on this forum. I would like to weigh-in with a thought about this.While I was just soaking in my Arctic, I noticed that my temperature was 102. Nothing new, but then I began to think about the no-heater debate that often occurs on this site. Considering that my set temperature is only 101, logically then I should be safe to assume that the heater would only be responsible to raise the water temp to 101 if necessary, before shutting off. Yet, I am over my set temp.
 The size of the heater is more to maintain temps while you are using the tub in extreme cold!!  Not for normal heating while cover is on.
While I was just soaking in my Arctic, I noticed that my temperature was 102. Nothing new, but then I began to think about the no-heater debate that often occurs on this site. Considering that my set temperature is only 101, logically then I should be safe to assume that the heater would only be responsible to raise the water temp to 101 if necessary, before shutting off. Yet, I am over my set temp.Now, I began thinking about the past several months. During that time our actual tub temp has always been at least one degree higher than our set temp. So is it fair to say that over the past several months the heater has not been used?
...HS doesn't use the heater to heats its water. My grandee heater has not turned on once since April and I have temps of 101 degrees in the evening when we tub. Hot Springs uses a thermal enhancement transferal system to maximally utilize the heat escape and capture from the low-energy high-filtration yield circulation pump to provide all the heat needed for this large tub. Other tubs need multi-thousand-watt expensive-to-run heaters to duplicate this very inexpensive behavior...
Oh, BTW...You don't really drive a Ford, do you? Â
