Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Original
Scum Water Line..can't find last post
« previous
next »
Print
Pages: [
1
Author
Topic: Scum Water Line..can't find last post (Read 5732 times)
tdowl5757
Guest
on:
July 09, 2005, 09:57:05 pm »
Hi and thanks for advice, cannot find the last post on this.
Just replaced old spa with new Jacuzzi 385 and shell is smooth & light color, getting bad greasy yellow water line, much worse than ever before.
Using Bromine now & all chem levels are proper, filters quite large and brand new.
My Questions:
1. Any difference between Bromine & Chlorine with respect to scummy water line?
2. What is the enzyme product mentioned in previous post?
3. Any other suggestions (other than showering before using spa) to prevent this?
Thanks again!
Logged
on:
Payton3485
Full Member
2005 Sundance Majesta
Re: Scum Water Line..can't find last post
Reply #1 on:
July 09, 2005, 10:54:48 pm »
--Not sure, one of the experts on the board can help you with this one.
--Stain & Scale Control (I use mine once a week)
--Make sure you have no lotions or sprays on yourself prior to entering the spa.
Logged
Haynes
Junior Member
2005 Down East Cape Cod/ Monongahela, PA
Reply #2 on:
July 09, 2005, 10:56:19 pm »
I am new to the hot tub scene. I had alot of water and scum problems when I first got the tub. After 1 month I changed the water and no more problems and NO more scum!
Logged
drober30
Full Member
Loving my HS Vanguard!
Reply #3 on:
July 10, 2005, 12:20:42 am »
You said all chem levels are good. Does that mean Calcium Hardness too?
I hade problems when I first filled my tub and after my first water change.
Both solved after I adjusted my Calcium Hardness. I needed to increase mine.
I use the approach that I want to add the least amount of chems to my water as possible.
I do not use foam away, enzyme control, stain and scale control or water clarifier.
I only use Dichlor, PH /up/down, Calcium Hardness increaser or alkaline increaser.
I'm still a rookie by all means but am doing very well.
Logged
hymbaw
Full Member
Reply #4 on:
July 10, 2005, 04:21:11 am »
Bromine or Chlorine ---- no difference
Stain and scale control - while important - has nothing to do with scum line!!
Biogard makes a product that is called "natural spa enzyme" that will reduce your scumline
Yes, showering will help becasuse a lot of that scum probably comes from the products that people are putting on to "moisturize" their skin(lotion and oil)
Logged
tony
Ultimate Member
2002 Optima
Reply #5 on:
July 10, 2005, 08:45:38 am »
Also Spa Perfect and LeisureTime Spa Enzyme(formerly Scum Gon).
Logged
lynnette
Junior Member
I love YaBB 1G - SP1!
Reply #6 on:
July 10, 2005, 08:48:14 am »
We have been using Biogard Natural Spa Enzyme for about 4 weeks, no scum line at all now. It says you can use this product with all chemicals. You just add once a week. Hope it works for you.
Lynnette
Logged
orlandoguy
Full Member
all you need is tub
Reply #7 on:
July 14, 2005, 03:04:42 pm »
I realized how cutthroat the hottub business was when I spent the whole week wet testing tubs and wound up with the jacuzzi j365 after much deliberation. The electrician sent by jacuzzi to hook p the 220 started pitching Vita Spa even though he worked at leats for the day, for jacuzzi. To satisfy my curiosity I checked out vita spa and found the controls to be flimsy, the mister a gimmick, and the overall performance not as good as jacuzzi. In the end it was between HS and jacuzzi and I can't wait to get off work as my tub went in today and is heating up.
Logged
Campsalot
Full Member
Sundance Maxxus Super Tub
Reply #8 on:
July 14, 2005, 03:30:22 pm »
I'm fighting the same battle. Checkout this thread! "Ring around the tub"
Logged
Lori
Senior Member
Saw It ... Wanted It ... Had A Fit ... Got It!
Reply #9 on:
July 14, 2005, 06:00:17 pm »
Congratulations Orlandoguy!
May you always have clean, hot, bubbly water!
Enjoy Spatopia, after work, that is!!!
Logged
Reply #9 on:
Print
Pages: [
1
« previous
next »
Original
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Take 42
