Author Topic: To dilute or not to dilute. That is the question?  (Read 3542 times)
matthewc
« on: January 06, 2005, 02:37:56 pm »
My local dealer says that it is OK to add chemicals to the tub without first diluting in water. However the instructions on the chemical pt say to dilute in water first.
What do you all do?
Re: To dilute or not to dilute. That is the questi
« Reply #1 on: January 06, 2005, 02:55:17 pm »
I pour mine into the middle of the tub and run the jets on low for a few minutes. Then I look to see if I spilled any on the surface of the near where I stand.
« Last Edit: January 06, 2005, 02:56:06 pm by wmccall »
salesdvl
« Reply #2 on: January 06, 2005, 02:58:25 pm »
I cant think of a chemical that would absolutely need to be diluted into a spa.  It is important for a vinyl liner pool to not have solid chemicals come in contact but spa shells are diff.
I say "NOT" to the original question.
Measure once, cut twice.
HotTubMan
  • My 2.1 cents, eh
« Reply #3 on: January 06, 2005, 03:52:19 pm »
Good advice above.
windsurfdog
« Reply #4 on: January 06, 2005, 05:15:13 pm »
The only one you 'might' consider dissolving before applying may be dry acid...... 8)
rocket
  • Life is good!
« Reply #5 on: January 06, 2005, 05:23:21 pm »
Soft tubs or spas with like liners do require diluting of the chemicals.  Otherwise, put jet pump on high and broadcast the chemicals into the water.
