Author Topic: Leaking tub  (Read 11734 times)
Buzzard bait
Leaking tub
« on: April 04, 2024, 02:57:17 pm »
10 year old Grandee has a slow leak. Loses about 2-3” of water a week. Dealer said they would have to take it into the shop. Anyone with experience with this?
Leaking tub
cranbiz
Re: Leaking tub
« Reply #1 on: April 04, 2024, 05:15:03 pm »
Well, that is for the convenience of the dealers tech. Water leaks can be tricky especially in a full foam tub. I'm sure they want to charge you for removing and reinstalling the tub as well as the cost to fix it.
Have you got any idea where it's leaking from? I would open it up and pull the panels to look for the leak. It could be a jet, it could be a line in the tub, pump, etc. If you can find the source, it might be an easy fix.
Buzzard bait
Re: Leaking tub
« Reply #2 on: April 07, 2024, 03:17:27 pm »
I did a cursory look. In a tough place to troubleshoot. One side not available. I’ll look a little closer to see if I can find anything.
Re: Leaking tub
