Author Topic: Hot Springs Spa Vac  (Read 2163 times)
navman6
Hot Springs Spa Vac
« on: February 11, 2021, 02:05:53 pm »
Has anybody used the Spa vac by HS ?
I am considering one.  In the past it was difficult scooping with a fine mesh pool debris screen.
Thanks!
Hot Springs Spa Vac
Sammi
Re: Hot Springs Spa Vac
« Reply #1 on: February 11, 2021, 02:16:27 pm »
Are you talking about the one similar to this? www.spa-daddy.com
If so I think the HS one is virtually the same if not exactly the same from what I can tell eyeballing it. I have e this one and it works great for small debris, sand/gravel. Depending on the amount of sediment you have to dip in a half dozen times but it works as advertised, and makes bottom cleaning simple.
CanadianSpaTech
« Reply #2 on: February 11, 2021, 05:59:34 pm »
Buy a Quick Drain You can use it as a vacuum as well as drain the spa rather quickly. Link: https://www.costco.ca/quickvac-quickdrain-spa-maintenance-system.product.10322940.html       You should be able to find it for a little cheaper than Costco
Sammi
« Reply #3 on: February 11, 2021, 08:17:20 pm »
That looks sweet!
