Author Topic: LED lighting system-the last to know  (Read 4352 times)
zacman
« on: September 23, 2004, 10:32:49 pm »
OK - at the risk of looking foolish, but with the hope that I might help someone like me - I will share this:
We have had the spa only a week.  An Optima with the sunglow light system.  When we used the spa the lights would change from color to color to color. . .   I thought that they should have designed the light so that you could stop it at one particular light - to prevent the rotation.  Didn't think you could do this - and the manual says nothing about this ability.  But I decided to play around with it - and once when I kept the light switch depressed for a while I seemed to be able to lock it on one color, tried again and could not do anything but turn it off. Now I am able to play with it and fix one color at at time. but not sure exactly how I am doing it, but only know now that it is possible..  So if anyone else out there thought, as I did, that you were stuck with only rotating lights, not so.
ttodd1
Re: LED lighting system-the last to know
« Reply #1 on: September 23, 2004, 10:37:55 pm »
If you turn the light on then off and back on within (I think) 3 seconds the light will go to the next program.  The lights change color slowly and the next is a little faster, and so on and so on til it gets to what I call a disco light that almost makes me sick to watch.  Somewhere in there is also the solid of each color.  As long as when you turn off the light you wait 5 seconds or more the light will use the same program as before.
windsurfdog
« Reply #2 on: September 23, 2004, 10:43:24 pm »
Zac,
Here's part of the instructions for the ColorGlo LED light I have in my tub.  I would think yours would operate similarly.
Lighting Mode Sequence:
• White
• Spectrum Slow Dance - slow fades cycling
through the color spectrum
• Sunburst - yellow and orange glow
• Blue
• Red
• Green
• Magenta - pink, blue, red glow
• Tidal Fade - slow fade through shades of blue
and green
• Afterburner Fade - slow fade through shades of
red, orange, yellow, pink, purple
• Color Burst - strobe effect change through the
color spectrum
Choosing Lighting Modes:
The ColorGloâ„¢ Multi-Color Spa Light comes preprogrammed with 10 exciting lighting modes.
• To advance to the next lighting mode, switch the
unit off and then on again within five seconds
• To resume a lighting mode, leave the unit
switched off to store the last lighting mode displayed
in memory. That same lighting mode will
display the next time the unit is switched on.
« Reply #3 on: September 24, 2004, 07:36:48 am »
Sounds like you didn't get your sunglow instruction sheet from your dealer.  The light operates similar to what Windsurfdog says, but I dont' think there are as many single mode colors as he lists.
If you can't get an instruction sheet, let me know and I'll send you a copy of mine.  Or maybe you can download one at Sundance's website.
« Last Edit: September 24, 2004, 07:39:36 am by Brewman »
saz
« Reply #4 on: September 24, 2004, 08:20:24 am »
I can totally agree with this.........if you're in the tub, and had maybe a little too much of the old sauce(!!) then the disco light is very VERY disturbing!
saz
zacman
« Reply #5 on: September 24, 2004, 10:20:18 am »
Brewman, you are correct.  I did not receive the instruction sheet re the light.  Went to the manual but found nothing about how it works there. I will stop by the dealer next week to pick one up. Thanks for your offer.  If the dealer does not  have one I will take you up on your offer.
bethshar
« Reply #6 on: September 24, 2004, 11:08:29 am »
I didn't get the istruction sheet either, but it is pretty easy to do.  Just keep pushing the ligtht button and it goes through the sequence of  - changing colors - off - red- off - green - off - blue - off, etc.  Only about six or so color settings.  If there is more to it than this let me know so I can get the instructions also.
stuart
« Reply #7 on: September 24, 2004, 11:18:50 am »
Turn it off, wait 2 seconds then back on to get to differant sequences.
« Reply #8 on: September 24, 2004, 02:45:19 pm »
Zacman-
Just PM me with an email address if you want the instructions.
