Author Topic: help identifying my hot tub  (Read 4107 times)
joshwhit
« on: December 11, 2019, 02:47:26 pm »
I just bought this house in Sydney Australia and it came with a hot tub, which we love!  I want to buy replacement filters and see if I can put it on a timer, but don't know the year make or model.
photos are here: https://photos.app.goo.gl/qC5yULJogdTKtuj88
Inside the panel it's got a Microspa controller whose label says:
ID: 0207-205002Serial 032312599
(a spiral logo that says GECKO)
model: uspa
options: 121-01-NE-LS-H1.0  DF GFCI-JJM
pump: 12FLA, 60LRA
ozone: 12FLA
heater: 12A
Input 120VAC 60Hz 12A
Re: help identifying my hot tub
« Reply #1 on: December 11, 2019, 05:28:29 pm »
Those pics and info are related to the off the shelf equipment installed in the spa that any spa maker could use so it won't help identify the spa itself. You'd want to look for a serial number or some kind of name plate for the spa which would most likely be in the equipment compartment somewhere if it exists. That would help determine the spa maker/model/year.
Otherwise post pics of the current filter including its end caps and maybe that will help (you might take the pics with a tape measure next to it showing its length and diameter).
joshwhit
« Reply #2 on: December 15, 2019, 07:46:35 pm »
thank you! I'll do that.
Dirk
« Reply #3 on: January 01, 2020, 09:06:14 pm »
The controller is Gecko
Here is a link to the manual
https://www.spastore.com.au/assets/files/Gecko%20Micro-Spa%20User%20Guide.pdf
