Author Topic: Attn Guests  (Read 7132 times)
huh?
  • "42"
Attn Guests
« on: August 24, 2004, 08:41:43 pm »
Come on in the waters fine.  Feel free to post a question.  No commitment to register.  Bounce something off of us.  Give us something to do....please.
Attn Guests
bethshar
Re: Attn Guests
« Reply #1 on: August 24, 2004, 08:52:44 pm »
Why aren't you in your hot tub?
ttodd1
Re: Attn Guests
« Reply #2 on: August 24, 2004, 09:17:36 pm »
OK but remember you asked..  What is the best way to move a hot tub?
stuart
Re: Attn Guests
« Reply #3 on: August 24, 2004, 09:32:40 pm »
               empty.......
ttodd1
Re: Attn Guests
« Reply #4 on: August 24, 2004, 09:34:55 pm »
I think I knew that one ::).  seriously, how best to move it 8-10 feet.?
Nhbeacon
  • Still a happy Siberian owner
Re: Attn Guests
« Reply #5 on: August 24, 2004, 09:39:56 pm »
Make sure to unplug it first....
Maybe the Hokey Pokey is what's all about?
stuart
Re: Attn Guests
« Reply #6 on: August 24, 2004, 09:45:22 pm »
What kind of spa is it? This does matter as far as how you cart it and lift it. Also, what part of the country are you? There are several spa moving companies that may be worth your while paying. They have the equipment and knowledge.
« Last Edit: August 24, 2004, 09:48:09 pm by stuart »
stiffy
Re: Attn Guests
« Reply #7 on: August 24, 2004, 09:57:09 pm »
solid ground with no obstructions in the way, I helped my dealer move in the tub and they used heavy duty conduit (pvc) to slide the tub into the notch I cut into my deck, moved around real easy then just eased them out from under the tub.
bulmer4nc
  • Now a Canes Fan.
Re: Attn Guests
« Reply #8 on: August 24, 2004, 10:12:46 pm »
is it OK to ask "why"??
ttodd1
Re: Attn Guests
« Reply #9 on: August 24, 2004, 10:48:30 pm »
Delivery of tub is this Friday  ;D
Slab where tub to go is not ready  >:(
Will have to put tub on other slab (in front of back door) till the new slab is ready.  so I will have to move it into place at some point.  And before you ask, no cannot cancel/postphone delivery.
I was trying to figure out how to do this.
ttodd1
Re: Attn Guests
« Reply #10 on: August 24, 2004, 10:49:19 pm »
It is a Sundance Cameo and in SC
« Last Edit: August 24, 2004, 10:50:00 pm by ttodd1 »
Constance
  • I love my Bahia
Re: Attn Guests
« Reply #11 on: August 24, 2004, 10:59:40 pm »
Awesome Tub-- Beautiful State 8)
Good Luck with the spa.
Re: Attn Guests
« Reply #12 on: August 24, 2004, 11:11:54 pm »
Without knowing more, can you:
Leave the tub up on it's side next to the slab? Once it's ready simply lay it down?
Set the spa on PVC as was mentioned above and roll it.
Set the spa on plywood and scoot it.
Have the dealer loan you a dolly and a guy to help.
Pay a dealer to do the job.
stuart
Re: Attn Guests
« Reply #13 on: August 25, 2004, 12:04:18 am »
OK, rolling it on PVC works great but only with the spa setting flat. If you try to roll it on anything on its side you will damage that cabinet. You can go to HomeDepot, Harbor freight or lowes and buy a 4 wheel dolly for about $20 or to your local rental yard and rent it for about $5 a day. Place plywood sheets over any rough terrain or uneven surface, put the dolly in the center of the footwell and roll it in place.
We've even used a furniture dolly on both sides in a pinch and moved them that way. I would offer the delivery crew a spiff to come back a week later and move it after hours provided the dealer doesn't mind this. Remember that you will still probably need the dolly as it wouldn’t be fair to the dealer to put the wear on his equipment without him making anything on it.
lobeknee
Re: Attn Guests
« Reply #14 on: August 25, 2004, 01:06:23 am »
Don't mean to change the subject, but Stuart what is a "spiff"? :-/
Re: Attn Guests
