Author Topic: How to check TDS?  (Read 3067 times)
bulmer4nc
  • Now a Canes Fan.
How to check TDS?
« on: August 16, 2004, 10:44:23 am »
Can someone tell me how to check TDS (total dissolved solids)?  I see this in many posts but don't know how to check.
How to check TDS?
CalicoskiesNC
Re: How to check TDS?
« Reply #1 on: August 16, 2004, 06:37:18 pm »
From what I've read, there are TDS strips for about $10/25ct but I dont think I would try them, I dont place much value in the strips.  The only other way to test for TDS is with some kind of portable meter I think, and those can be expensive.  Here's a link for one I liked:
http://www.intheswim.com/catalog.cfm/dest/product/deptid/1317/productid/229/storeid/154
I read somewhere that when you get into the 2-3mo range on your water and it starts to feel different and smell a bit funky and you have trouble stabilizing your pH and ALK and maybe its cloudy and has excessive foam...then its high in TDS and you've got to change it.  I have it in my mind from somewhere that you cant miss the signs.  I know that doesnt sound very technical, and maybe someone else with more knowledge here can answer.  I have not seen drop test kits for TDS.
« Last Edit: August 16, 2004, 06:42:53 pm by CalicoskiesNC »
« Reply #2 on: August 16, 2004, 10:11:59 pm »
Another common option is your dealer may be able to test it for you.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #3 on: August 17, 2004, 07:53:49 am »
If you are using dichlor, you should be more concerned with Cyanuric acid.  A high level of Cyanuric Acid will cause more problems than a high level of TDS.
Shut_Down_Stranger
conductivity meter
« Reply #4 on: August 18, 2004, 12:26:13 am »
conductivity meter
