Author Topic: what chemicals to keep water clean and clear in a wood fired hot tub  (Read 3950 times)
stvee
Hi,
 I have a wood fired hot tub. with a molded plastic inside, an external stainless steel heater and a sand filtration system.
The water still gets manky ( and probably full of bacteria) after a few sessions........
People use it daily and ideally i don't want to change the water more than once a week.
What chemicals do you recommend i use to keep the water clean, ideally NON chlorine as that will corrode the heater?
Many Thanks- Steve
Re: what chemicals to keep water clean and clear in a wood fired hot tub
« Reply #1 on: December 21, 2016, 05:25:41 pm »
Hi,
Many Thanks- Steve
If you want clean, sanitized water, you have to use chlorine or bromine. The heater is SS. It will burn up before it gets wrecked by chlorine.
BullFrogSpasMN
« Reply #2 on: December 21, 2016, 05:33:59 pm »
your options would be: Granular Chlorine, Bromine Tablets, Baqua-Spa/Hydrogen Peroxide, or you could plumb an in-line ozonator in and combine that with a silver ion cartridge and use small amounts of non-chlorine shock after each use
Dr. Spa™ Ret.
« Reply #3 on: December 22, 2016, 09:50:26 am »
Chlorine, in the small amounts used in hot tubs,  should have no effect on the heater.
stvee
« Reply #4 on: December 23, 2016, 05:17:07 am »
Great,
Thank you for all advice.
« Reply #5 on: December 23, 2016, 02:48:48 pm »
BFSM the problem with this is your still supplementing with chlorine. I like to reverse think it. Start figuring out chlorine and supplement with ions and oxidizer.
