Author Topic: Intermittent FLO error with new filters, flow switch and circ pump  (Read 2168 times)
fixitmyself
I recently replaced the circ pump and flow switch due to FLO errors.  Now I have an intermittent FLO error.  When the error is on, the circ pump still runs, but the other two pumps do not.  Any thoughts?
Re: Intermittent FLO error with new filters, flow switch and circ pump
« Reply #1 on: October 16, 2016, 11:47:00 pm »
Most common problem would be the connections at the motherboard. Those tiny little things are often the culprit. Check them one by one.
HTH
Clayterickson
« Reply #2 on: November 07, 2016, 01:46:24 pm »
Did you ever figure that problem out.  I am.having the same problem.
