Author Topic: Water temperature  (Read 12158 times)
Re: Water temperature
« Reply #30 on: April 05, 2016, 11:54:40 am »
106 all through the worst part of winter, but I suspect that is more like 105 if I took out an accurate temperature.  It will get turned down to 102 for the summer.
Hydrotherapy Guru
« Reply #31 on: May 22, 2016, 10:09:44 pm »
I wonder how accurate the temperature readings are? 100 is too cool for me!
« Reply #32 on: May 23, 2016, 07:21:26 am »
Part of it is the surrounding air temp and wind.  In anything above body temp the body needs to cool down and in a hot tub that occurs via breathing and the skin above the water.  If its 10F outside I can stay in 104 degree water for an hour. If its 80F outside, not quite as long.
