Author Topic: Marquis Spirit 160 GPM pump upgrade  (Read 7548 times)
Tomb
« on: June 11, 2015, 08:33:51 am »
I'm buying a new Marquis Spirit and I'm wondering if I should get the 160 GPM pump upgrade or is the 120 GPM pump just fine? Are most people happy with the standard pump?
MarKee
Re: Marquis Spirit 160 GPM pump upgrade
« Reply #1 on: June 11, 2015, 06:19:02 pm »
Hey TomB, congrats the Spirit is an awesome tub!  It kind of depends on your electrical situation.  The standard Spirit model with the HP120 pump is convenient because you don't need to run 220v/240v wiring to it, and it can run on a standard 110v plug-in.  But if running the wiring isn't going to be a huge issue and not too costly, I would definitely upgrade the pump to the MP160.  You will get an extra 40 gallons per minute of water coming through the jets.  Either way I think you will be happy with the tub, you just need to consider the cost of upgrading the pump and how much it will be to run the electrical out to your tub.  One other advantage of running it on 220v/240v is that the water will heat about 3 times faster than running it on 110v.
Hottubguy
« Reply #2 on: June 11, 2015, 06:40:29 pm »
+1 to what Markee said.  The Spirit is a great tub!
Tomb
« Reply #3 on: June 11, 2015, 07:23:15 pm »
Thanks very much for your help. We already had 220/240 ran and the dealer said they would upgrade for $100.00 so I did.
« Reply #4 on: June 11, 2015, 07:53:20 pm »
+2 It will also cost slightly more to run the bigger pump. Slightly noisier moving more water also. Some people are just GPM/HP people. Be nice if you could feel them both?
MarKee
« Reply #5 on: June 12, 2015, 06:39:07 pm »
$100 for that upgrade is a good deal and I think you'll find it was more than worth it!  Enjoy the tub!
« Reply #6 on: June 12, 2015, 06:53:23 pm »
Would they let you try it with the regular pump for a month and then consider the swap? As TMan stated it will cost a bit more to run so if the lesser HP pump works fine then I'd stick with that. If you find out the spa is underpowered then you could ask for the swap. Sometimes an upgrade like that has merit and other times it just makes people feel like they're getting a better option because its more powerful (ala Tim Allen grunting about power tools).
« Last Edit: June 12, 2015, 06:55:28 pm by Spatech_tuo »
Hottubguy
« Reply #7 on: June 12, 2015, 09:19:30 pm »
It's definetely worth the $100. It's a very noticeable difference
Gale
« Reply #8 on: June 22, 2017, 01:41:30 pm »
Hello, I am considering a Marquis Spirit with the pump upgrade and I'm wondering if you are happy with your purchase now that you have had it for some time? Would love info from anyone else who has one as well. Thanks :-)
Copyright ©1998-2024, Whats The Best, Inc. All rights reserved. Site by Take 42
