Author Topic: Hot tub surface  (Read 2997 times)
Riley012
Hot tub surface
« on: May 15, 2015, 09:22:11 pm »
I have this light sand paper scaly coating on my hot tub surface. Can anyone tell me what mite be causing this? You can rub most of it off with your hand, except at the water line where it is a little harder to get off. Thanks for any help
Hot tub surface
Kev B
Re: Hot tub surface
« Reply #1 on: May 16, 2015, 10:38:30 am »
 Proper water balance is a major key to preventing sugar scale from forming. What is your ph and alkalinity readings?
MarKee
Re: Hot tub surface
« Reply #2 on: May 18, 2015, 01:33:41 am »
It's caused by the pH getting very high and the calcium coming out of suspension in the water. The sand paper feel is calcium sticking to the sides of the water. Whatever you do, don't drain the spa because it will harden and be very hard to remove. Best way to remove it is to get pH down and get the pH really low in the spa. That will soften it up and allow it to be wiped off with a little bit of scrubbing. Mr Clean Magic Erasers work well for removing the scale.
seabeece2
Re: Hot tub surface
« Reply #3 on: May 18, 2015, 10:49:09 am »
I'm having trouble with high PH as well can I just use baking soda to bring it down.
Re: Hot tub surface
« Reply #4 on: May 18, 2015, 11:45:29 am »
Baking soda will raise PH and alkalinity.
seabeece2
Re: Hot tub surface
« Reply #5 on: May 18, 2015, 01:14:25 pm »
What's the best way to lower it?
Sam
Re: Hot tub surface
« Reply #6 on: May 18, 2015, 03:57:47 pm »
Go to a hot tub store and ask for PH reducer.
Re: Hot tub surface
