Author Topic: hot tub base  (Read 11517 times)
leweezo
hot tub base
« on: January 13, 2015, 09:33:24 am »
Does anyone know if there is a base (leveling kind) that you can buy to go ontop of a deck that has uneven boards?  I know the tub will compress some of the boards but a couple high spots are directly over  a post and trhat will be harder to compress..  We are talking about 1/8 a inch
hot tub base
gizmodo
Re: hot tub base
« Reply #1 on: January 13, 2015, 03:52:57 pm »
Try a palm or belt sander.
Dr. Spaâ„¢ Ret.
Re: hot tub base
« Reply #2 on: January 13, 2015, 04:04:33 pm »
What about laying a sheet of high density Rigid Foam Insulation Board under the spa. It should compress to the contour of the deck, and would add some extra insulation.
Re: hot tub base
« Reply #3 on: January 13, 2015, 06:12:08 pm »
I like it.
leweezo
Re: hot tub base
« Reply #4 on: January 13, 2015, 09:59:33 pm »
Wow! is that available @ home depot or lowes?   Sounds  like a great fix..  I just wanna keep stress off my shell..
leweezo
Re: hot tub base
« Reply #5 on: January 13, 2015, 10:23:28 pm »
ooh ooh, is that the board that they use under vinyl siding as insulation?
Dr. Spaâ„¢ Ret.
Re: hot tub base
« Reply #6 on: January 13, 2015, 11:58:01 pm »
I think it would be a higher density. Maybe the Blue Board? Something about an inch thick (thicker might compress too much, thinner not enough).
Re: hot tub base
« Reply #7 on: January 14, 2015, 06:00:33 am »
leweezo
Re: hot tub base
« Reply #8 on: January 14, 2015, 05:11:51 pm »
Thanks for the help! Blue board is what I have!!.. I will still sand it down..  I am wondering how much stress a 1/8th inch difference would cause?.. I know the manu says "smooth surface" but is that a generic discaliner?
Re: hot tub base
« Reply #9 on: January 14, 2015, 07:26:00 pm »
It could damage one tub while not on another. And they could be same model/man....I don't think anyone can answer this. May or may not shorten it's life. Arctic uses a big solid piece of fiberglass bottom as an option. Probably wouldn't effect that one at all. Others have pretty solid ABS pans also (Marquis) You didn't mention a brand?
leweezo
Re: hot tub base
« Reply #10 on: January 15, 2015, 01:01:22 pm »
sundance 680 Edison
TwinCitiesHotSpring
Re: hot tub base
« Reply #11 on: January 15, 2015, 02:14:37 pm »
sand it down and do it right imo... please don't buy a brand new tub and place it on a $15 sheet of crappy foamboard
Budule
Re: hot tub base
« Reply #12 on: January 15, 2015, 03:04:55 pm »
Agree on that , I would look to rent a large drum sander that you stand up and use....
Re: hot tub base
« Reply #13 on: January 15, 2015, 05:49:59 pm »
Plain it down, sanding will take freaking forever unless you get a good belt sander and varying grits, start course. They will both cost the same if you don't have the sander/plainer. Plainer will only take a couple 3 passes, 20 minutes
Oh and be careful if it's a planer. Don't take any more off the boards than you have to to maintain board integrity. Unless your very confident in your deck construction.
« Last Edit: January 15, 2015, 05:52:35 pm by Tman122 »
leweezo
Re: hot tub base
« Reply #14 on: January 15, 2015, 06:54:34 pm »
i will start 2morow... ZHey Tmnan  what do you think about the Sundance  shell strength?
Re: hot tub base
