Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Original
GFCI Trips when set temperature is achieved
« previous
next »
Print
Pages: [
1
Author
Topic: GFCI Trips when set temperature is achieved (Read 3017 times)
palmettospecialties
Junior Member
on:
October 05, 2014, 02:39:11 pm »
I have a 110 v, spa, one two speed pump, no blower or ozone generator. Everything works great until the water reaches the set temperature, at which time gfci trips. Any advice would be greatly appreciated.
Logged
on:
DaveMc
Full Member
Re: GFCI Trips when set temperature is achieved
Reply #1 on:
October 05, 2014, 10:17:49 pm »
You know since this is an electrical question I would suggest this site---
http://www.diychatroom.com/f18/
---as electricians will answer your questions---and sometimes they will debate among themselves the answer--but like this site it is a a very good resource.
Logged
Isaac-1
Full Member
Reply #2 on:
October 06, 2014, 01:52:37 am »
Is this a GFCI outlet that trips, a GFCI breaker, or is it the GFCI on the cord? In any case there are two possibilities, one it is doing its job, or it has went bad and is now overly sensitive. In my general experience dealing with GFCI equipment it could be either one.
Logged
wingizzmo
Junior Member
Reply #3 on:
October 06, 2014, 09:50:09 am »
Also brings to mind something that has happened to me before If the cord on the spa has a GFCI built into it and your plugging into a outside outlet or breaker that is also a GFCI that could be an issue .
Logged
palmettospecialties
Junior Member
Reply #4 on:
October 06, 2014, 10:50:48 am »
There are 2 GFCIs, one on tub, one in breaker box. The one in the breaker box tripped several times initially. I connected hot tub to a non GFCI protected outlet, and the GFCI on the tub tripped, indicating to me that there is a problem and that the GFCIs are working correctly.
Logged
Dr. Spaâ„¢ Ret.
Ultimate Member
Retired (mostly) from the industry after 33 years
Reply #5 on:
October 06, 2014, 11:15:35 am »
It's possible that your heater element is failing. It could have a microscopic hole in it, that expands (enlarges) as it heats up. When it gets hot enough and has enlarged far enough, it allows enough water to get in to cause a short, tripping the GFCI.
Logged
palmettospecialties
Junior Member
Reply #6 on:
October 06, 2014, 11:41:12 am »
I am replacing heating element, will let you know if that does it. Thank You!
Logged
DaveMc
Full Member
Reply #7 on:
October 06, 2014, 11:53:27 am »
Looks like Dr Spa nails it again--also 3 responses here---
http://www.diychatroom.com/f18/gfci-trips-207503/
Logged
clover
Full Member
Reply #8 on:
October 06, 2014, 12:11:42 pm »
Before replacing the heater, let's test it to see if it is really the problem. This is easily accomplished by simply disconnecting the heater wires and see if the GFCI reacts differently.
If it still trips, disconnect each electrical motor, or accessory one at a time to see if the GFCI holds. IF and When, the GFCI holds, reconnect each individual item that you disconnected to verify the single item as being the culprit.
If you have an ohm's meter, measure resistance to ground of each electrical component. There should be no resistance to ground from any of the power connections.
Logged
DaveMc
Full Member
Reply #9 on:
October 06, 2014, 01:28:19 pm »
Clover
Great---clear and concise advice--to confirm the actual culprit--if he does that he will be positive he has found the fault---otherwise replacing items is a matter of trial and error.
Dr Spas answer was quite logical---may be he has ran in to that in the past.
David
Logged
Reply #9 on:
Print
Pages: [
1
« previous
next »
Original
Jump to:
=> Hot Tub Forum
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Take 42
