Author Topic: Hot tub pad  (Read 2356 times)
Buzzard bait
Hot tub pad
« on: June 07, 2014, 02:38:00 pm »
Has anyone used the EZ PAD (ezpads.com) for their tub.  Sounds too good to be true./
Hot tub pad
aeajr
Re: Hot tub pad
« Reply #1 on: July 03, 2014, 06:27:45 pm »
Have not used them.
What is it about these that you find attractive?  You still have to do the site prep.   You have a stable level surface.
Likely to be less expensive than concrete, for sure.
Basically it is a big pad.    When I had a blow up bubble spa I put it on those interlocking square foam pads you put on a shop floor.   Same idea.  Worked great.
Re: Hot tub pad
