Author Topic: wiring question  (Read 2599 times)
mowin
wiring question
« on: May 04, 2014, 07:34:45 pm »
Where my tub will be going, there is a 220v 50 amp outlet wired to my main panel(50' away) with 8-4 copper wire.  I plan on switching the outlet to a disconnect box with a 50 amp gfci. This disconnect box will be about 10' from the tub.  Should I use 6-4 from the disconnect to the spa? Or match the 8-4?
wiring question
rosewoodsteel
Re: wiring question
« Reply #1 on: May 04, 2014, 08:25:00 pm »
Mowin, 6 4 sounds good to me.   I think, however, the disconnect should be not less than 5' from the tub.    I'm sure others will chime in on this.
Dr. Spa™ Ret.
Re: wiring question
« Reply #2 on: May 04, 2014, 08:29:08 pm »
10' is not less than 5'       ;-)
Topline Mike
Re: wiring question
« Reply #3 on: May 04, 2014, 08:39:11 pm »
This information might be in your owners manual.
My jacuzzi reads:  "When using wire larger than #6, add a junction box near the spa and reduce to short lengths of #8 wire to connect to the spa".
Re: wiring question
