Author Topic: degrees  (Read 4291 times)
relaxpa
degrees
« on: December 12, 2013, 04:20:39 pm »
Whats the ideal degree average for a hot tub in the winter months?
degrees
GGRANDEE
Re: degrees
« Reply #1 on: December 12, 2013, 04:24:00 pm »
Set mine at 103 degrees. It works well due to the temp dropping to 100 degrees after a 20 min. soak. 8)
clover
Re: degrees
« Reply #2 on: December 12, 2013, 04:47:00 pm »
The body is 98.6°, comfort zone is 102°, really cold weather, 104°
Re: degrees
« Reply #3 on: December 12, 2013, 05:24:21 pm »
I like 102 if your going to stay in for any length. Even when it's below freezing.
Re: degrees
« Reply #4 on: December 12, 2013, 06:02:53 pm »
These are all good answers. I will add whats 102 in one tub might be 101 or 103 in another tub.  Also, wind plays a little bit of a factor.  102 is good if I want to stay in for 20 to 30 minutes.   If my arthritis is acting up or I have some sore back musles 104-105 with jets going feels great.
clover
Re: degrees
« Reply #5 on: December 12, 2013, 10:55:55 pm »
You will get to a point when your body will tell you the temperature of the water without even looking.  Your getting into hot water, but you are going to enjoy it.
Re: degrees
« Reply #6 on: December 13, 2013, 07:23:49 am »
Your absolutely right, I can tell the temp to within .5 degrees without looking under most circumstances.
Spoiledrotten
Re: degrees
« Reply #7 on: December 13, 2013, 08:15:15 am »
That's some talented internal thermometers!  :)
I can tell when mines within 4 - 5 degrees.  ;D
Re: degrees
