Author Topic: Green water  (Read 2135 times)
ChrisDK
Green water
« on: November 17, 2013, 10:30:34 am »
Had the tub for 3½ months now, it's used every day, chlorine added after use and shocked once a week.The water is tested every 2nd day. I have also cleaned the filters on time every month.
For the first 2½ months no problems, chlorine added every day, PH down when needed and non chlorine shock every saturday.
I ran dry of the original chlorine granules so changed over to another brand as I couldn't get the same, I noticed after a few days that now instead of PH rising, it keeps dropping so I have to use PH up.
Over the last week the water has started to go green, and as it has been over 3 months now is the time to change the water.
I changed the water yesterday and all was fine this morning, so I adjusted the PH, left it 30 mins and added a good dose of chlorine granules.
Came back to it 2 hours later and it's greener than ever!!
I am thinking maybe I haven't been adding enough chlorine over a long period and now have algae in the pipes.
Normally I add enough chlorine to get to 2ppm but if I test it 12 hours later it reads 0, I thought the ozone was breaking it down.
I have shocked it and added clarifier, so if the water clears up should I ditch it, refill and clean the filters?
Here's how it looks now
Green water
bob snader
Re: Green water
« Reply #1 on: November 17, 2013, 12:29:17 pm »
Green water is usually not enough sanitizer.
Yes, ozone does break down chlorine among other things. Personally speaking, I'm not a big believer in ozonators. I used to use one and have disconnected since saw very little advantage in them at all.
Has the use of your hot tub increased? More users and/or increased usage of a hot tub will result in the chlorine being spent faster which of course means you need to put more in.
I would shock the heck out of it until the water is clear (a couple days to a week). I would also increase your 2ppm to at least 3 (the recommended is 3 to 5... and I don't for a minute believe this 2ppm stuff if an ozonator is present)
You also mentioned that you're shocking with a non chlorine shock. If you're using dichlor for your regular maintenance then you should probably also use dichlor for shocking. At least I find it a lot easier and more reliable.
ChrisDK
Re: Green water
« Reply #2 on: November 17, 2013, 03:04:14 pm »
Thanks Bob.
The water is now looking clear again after more chlorine and shock.
I will clean the filter tomorrow and make sure I keep the levels a little higher.
Re: Green water
