Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Original
Chemical order
« previous
next »
Print
Pages: [
1
Author
Topic: Chemical order (Read 2999 times)
vangoghsear
Full Member
Chemical order
on:
July 15, 2013, 08:00:55 pm »
I have a pretty good idea about how to add the chemicals, but I thought I'd ask the experts here about some of the order.
My main reason for asking is I want to add Non Chlorine shock, but I need to raise my chlorine level? Can I do them at the same time, or do I do one first then the other, or do I need to leave some time between them?
Anyway, what is the order for adding chemicals?
Logged
Chemical order
on:
goneaway
Full Member
Re: Chemical order
Reply #1 on:
July 16, 2013, 04:04:04 am »
I'm also keen to learn, and whether chemicals should initially be added cold.
Logged
Sam
Senior Member
Re: Chemical order
Reply #2 on:
July 16, 2013, 06:12:34 pm »
In most instances there isn't really a correct order of what to add as far as I know. I've seen an enzyme that says not to shock directly before or after, but most of the time I don't think it matters. If it doesn't say anything in the instructions, I wouldn't worry about it, though it isn't a bad idea to wait a few minutes between products. I wouldn't add granular products to cold water as they don't dissolve as well and could settle on the shell possibly causing damage.
Logged
vangoghsear
Full Member
Re: Chemical order
Reply #3 on:
July 16, 2013, 07:00:40 pm »
Thanks Sam.
Logged
Ultimate Member
Re: Chemical order
Reply #4 on:
July 16, 2013, 10:56:24 pm »
Yet to fail me or a customer, Shock first run main pump on low 20 min cycle, then good dose of chlorine, run pump 20 min. Then add one shot of clarifier or one line on side of bottle if using Leisure time, run pump 20 min. adj PH/alk as needed..
Logged
vangoghsear
Full Member
Re: Chemical order
Reply #5 on:
July 17, 2013, 08:08:27 am »
Thanks JJ! That's exactly the kind of advice I was looking for.
Logged
Re: Chemical order
Reply #5 on:
Print
Pages: [
1
« previous
next »
Original
Chemical order
Jump to:
=> Hot Tub Forum
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Take 42
