Author Topic: no heat 2006 tiger river sumtran spa  (Read 24494 times)
jaysea
« on: January 24, 2013, 05:08:22 pm »
No heat have tried new heater relay board, didn't fix, tried  new IQ2020 box no fix, circulation pump working fine, all jets work, i have green and red steady lites on the main board, it's a 220v heater, there is no power to the heater.
1. can the thermistors cause no power to the heater?
2. can the top side control panel cause no power to the heater?
3. how to check thermistors if they can cause the problem?
P.S   I did have a spa tech. tell me the topside control panel can cause this problem, says the logic is in the top side control panel, sends 2 signals 1 turns on the led on the circuit board and the 2nd signal turns on the relay to send power to the heater.
But then again i have been told by another spa tech. that he has never seen a topside control panel cause a no heat problem.
Help please.  how to check thermistors?
Dr. Spaâ„¢ Ret.
Re: no heat 2006 tiger river sumtran spa
« Reply #1 on: January 24, 2013, 06:38:03 pm »
You replaced the heater, and that didn't fix it?
Tell me, did you actually do any proper testing and diagnostics? Or did you just blindly start guessing and replacing parts at random?
jaysea
« Reply #2 on: January 24, 2013, 07:12:49 pm »
NO I DIDN'T CHANGE THE HEATER, THERE'S NO POWER GOING TO THE HEATER.
YeS A SPA TECH SAID IT WAS THE MAIN BOARD, SO THE IQ 2020 BOX WAS CHANGED, THAT DIDNT CHANGE ATHING.
tjr
« Reply #3 on: January 24, 2013, 07:25:48 pm »
If the lim ok and heater on idiot lights are steady,and you have a new iq2020 then the gfci/circuit breaker is not working or the spa is not wired correctly.
tjr
« Reply #4 on: January 24, 2013, 07:43:01 pm »
Is spa wired for 120 or 230 volts.
jaysea
« Reply #5 on: January 24, 2013, 07:46:32 pm »
gfci/circuit breaker is WORKING THERE IS 220V TO THE HEATER RELAY BOARD AT TERMINALS 1 & 3 AND THE SPA HAS BEEN WIRED THIS WAY FOR 7 YEARS, BY A CERTIFIED ELECTRICIAN AND CHECKED BY THE SPA TECH.wHAT ELSE YOU GOT I HAVE HEARD ALL THESE THINGS NOT BEING AN ASS JUST TRYING TO GET THIS THING FIXED.  aRE YOU ANOTHER WHO DOESN;T THINK THE CONTROL HEAD COULD CAUSE THIS OR.
jaysea
« Reply #6 on: January 24, 2013, 07:47:42 pm »
220
« Last Edit: January 24, 2013, 07:49:53 pm by jaysea »
tjr
« Reply #7 on: January 24, 2013, 07:59:45 pm »
Whats the voltage across H1 and H2 at the HRB?What jumpers are installed in Terminal block? Did you check program jumpers for 220volt?Is the power light on control head solid red not blinking? I am just trying to eliminate all possible reasons for your no heat situation.
tjr
« Reply #8 on: January 24, 2013, 08:04:57 pm »
The control head in the 2006 should have no effect on the heater.
jaysea
« Reply #9 on: January 24, 2013, 08:55:10 pm »
NO VOLTAGE AT H1 H2 1 JUMPER   AT 4/ 5      ON MAIN C/Board jumpers are installed on     1, 3, 9    control head  SOLID NO BLINKing
« Last Edit: January 25, 2013, 12:26:07 am by jaysea »
tjr
« Reply #10 on: January 24, 2013, 09:09:02 pm »
Is the summer timer on or off?
jaysea
« Reply #11 on: January 24, 2013, 09:10:24 pm »
Another question if the circulation pump wasn't putting out enough pressure would the heater led be lit on the main board? it is lit.
« Last Edit: January 24, 2013, 09:12:39 pm by jaysea »
jaysea
« Reply #12 on: January 24, 2013, 09:11:24 pm »
control panel is unlocked.
jaysea
« Reply #13 on: January 24, 2013, 09:13:44 pm »
can the thermisters cause this. how to test?no one has answered this question yet
tjr
« Reply #14 on: January 24, 2013, 09:19:34 pm »
the green lim ok light means the hilimit thermistor is good the red heater on means the temp control thermistor is calling for heat. so they are both working. the only time you will see a thermistor fail is usually rodents chewing them up or from being cracked from over tightening.
