Author Topic: Owners Manual for an older HotSpring Sovereign  (Read 12695 times)
Tonyp884
« on: September 03, 2012, 07:39:52 pm »
I would LOVE to find an owners manual or a copy, for an older HotSpring Sovereign Serial # I-111846.
My unit is older than the pdf manuals that are available on the HotSpring site.
Also, can anyone tell me the date of manufacture based upon the serial number?
I love this spa, but I am going to convert it to 220 volt next month!
Thanks,
Tony P
New Salem, NC
Dr. Spa™ Ret.
Re: Owners Manual for an older HotSpring Sovereign
« Reply #1 on: September 03, 2012, 09:37:42 pm »
Built in the first quarter of 1991
Gallons   300
Dry Weight (lbs)   530
Wet Weight (lbs)   3,035
Footprint Dimensions   6' 4" x 7' 7"
Electrical Specifications   110 Volt 20 Amp Dedicated Circuit
Original Selling Price (Approx.)   $5,695
« Reply #2 on: September 03, 2012, 09:58:36 pm »
That spa was made to run on either 220 or 110, but is not convertible. Sorry.
You can do it, but you have to start by buying a new heater - you can buy the original type of system: square heater box and twin heater elements. Still available, BTW. You can also install the new type of heater, which has a Power Down Reset system. Kind of cool system, if you ask me.
But in any event, you would then need to rewire the relay which controls the heater, and you will have to run a 30Amp, 220Volt, GFI-protected circuit to run just the heater. The rest of the spa still runs on 110volt, just as it does now. It's a lot of work, and if done wrong, could be dangerous.
I would recommend that you simply keep a real good cover on the spa, set the temp and enjoy it.
HTH
« Last Edit: September 03, 2012, 10:02:09 pm by Chas »
Tonyp884
« Reply #3 on: September 06, 2012, 06:00:08 am »
Thanks guys. An e-mail to the manufacturer got me a pdf manual.
And after using the spa a few days, maybe the 110 volt won't be so bad!
Is it possible to switch out a couple of the jets?
Actually not a bad spa for $400. And it looks great for a 1991 model.
Tony P
« Reply #4 on: September 07, 2012, 10:54:14 am »
Jets can be changed out - it uses the Hydro-Air "Versassage" jets - part number 31840 from Watkins.
Looks like this _
steven
« Reply #5 on: October 14, 2012, 11:55:21 am »
Tony - I am also in need of a 1991 Owners Manual.  Eould you be willing to post the PDF so I could download?
Thanks,
Hot Spring Ace
« Reply #6 on: October 14, 2012, 07:54:56 pm »
Thanks,
or call 800-999-4688
